Old 08-11-2003, 03:00 PM
flashbak flashbak is offline
Default OS X/Protools 6.01/Waves 4.0 not finding Waves Plug-Ins
I was wondering if someone here might be able to help. We're running Mac OS X on a G4 with PT 6.01. I just downloaded the Waves 4.0 software as well as going through the authorization process successfully. The problem is that none of the Waves Plug-Ins are loading. The pdf file states to make sure the Waveshell file is copied to the Digi plug-in directory. So we manually moved both the WaveShell-DAE 4.0_9 and WaveShell-DAE 4.0_X into the Digidesign Plug-In folder. However, according to the instructions when Protools launches the Waveshell file should interact with us prompting us for the location of the Waves plug-ins. This never happens and hence none of the Wave plugins are found. Your help is appreciated. Thanks!
Old 08-11-2003, 03:06 PM
Slim Shady Slim Shady is offline
Default Re: OS X/Protools 6.01/Waves 4.0 not finding Waves Plug-Ins
Which version of ProTools are you running? If you're on an LE system (mbox, 001, 002, 002r) I'm pretty sure you need the Waveshell RTAS, not Waveshell DAE. Waveshell DAE is for TDM/HD systems if I remember correctly.
Old 08-11-2003, 03:22 PM
I'm running v 6.01 LE for the 002.
Old 08-11-2003, 03:25 PM
So, you need waveshell RTAS - have you tried that?
bopsi bopsi is offline
you need waves shell RTAS, not DAE
good luck
Old 08-11-2003, 05:53 PM
Thanks folks! I'll look into getting it.
Old 08-11-2003, 06:16 PM
Sorry to question you folks, but are you sure about this Waveshell RTAS info? So far I've been unable to locate that Waveshell (RTAS) on waves site. Does anyone happen to have a link to it?
Old 08-11-2003, 06:38 PM
Avid's Avatar
Avid Avid is offline
Administrator
According to the information we have on this download posted on our website, this Waveshell is for both TDM and LE. The text was copied directly from Waves:
WaveShell-DAE 4.0.1_X
WaveShell-DAE 4.0.1_X fixes some problems occuring when issuing rapid Play/Stop commands. If you are using Pro-Tools TDM/LE 6.0 or higher, it is recommended to use this WaveShell.
Installation: Go to Digidedign’s Plug-Ins folder (Your Hard Disk / Library/ Application Support/Digidesign/Plug-Ins), trash WaveShell DAE 4.0_X and replace it with WaveShell-DAE 4.0.1_X .
<font size="2" face="Verdana, Arial">the link is to their website download:
http://www.digidesign.com/download/waves
Administrator
Old 08-11-2003, 07:02 PM
Digidesign Admin,
Thanks for the clarification! [img]images/icons/smile.gif[/img]
Waves 6.0.6 and Pro Tools LE 8 - "Select Waves Plug-ins Folder" - Windows XP toustab 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 19 03-14-2009 01:13 PM
Plugs Advice: Sony vs Waves - Sonalksis vs Waves? John J. 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 12-08-2005 01:31 PM
WAVES Protools7 update and Waves tech support x9blade 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 11-11-2005 06:24 PM
Waves Plug ins will not install in protools rspears 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 08-11-2004 06:20 PM
Waves 4 Plug-ins and Waves 3 rj333 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-03-2004 08:31 AM
