which flavor of SMPTE?
I posted this in the HD for Mac forum, but since ext. video sync is involved, perhpas someone here has an answer.
I have to transfer five or six songs from 2" 24 track analog tape to Pro Tools HD. These are tapes that I worked on over twenty years ago. There is SMPTE on track 24, which was probably used for mixing automation as I am certain MIDI was not involved and no 24 trk. "slaves" were made. I am not sure if these tapes were striped with 29.97 FPS or 30 FPS SMPTE, and it is not marked one way or the other. If I sync PT HD up to the 24 track machine using whatever synchronizer the studio has (probably a Linx Timeline), ext. video sync. ref, and a Sync I/O, does it matter if the existing SMPTE is 29.97 or 30.00. And how do I set up the Pro Tools session in terms of time code? Mark |
Re: which flavor of SMPTE?
Why do you need to use the SMPTE at all? If there are no slaves and no midi, why bother with the SMPTE track? It's not going to serve any purpose. Syncing the 2" to protools with SMPTE and just hitting play on the 2" and hitting record in protools will be identical regardless of the timecode setting at this point since you aren't sync'ing anything else to it. So just forget the timecode and do the transfer.
Derek Jones Sound Engineer / Producer / Composer Derek Jones Linkedin Megatrax Recording Studios Megatrax Studios Yelp Page A-list Music Artist Page |
You're probably right, but ....
I wanted to maintain the possibility to transfer any overdubs done on the PT session (new vocals) back onto the 2" tape at a later date, since my client is still living in the 80s. So the question remains ....does it matter if the unknown pre-recorded SMPTE frame rate on the 2" tape is 29.97 or 30 fps, if I sync up the two. And is my assumption correct that I would set up PT for 29.97 since I will be using ext. video sync? I guess my main concern is the pitch of the instruments, or is that a concern? Mark |
How do you want to lock it up?
1) The proper way with the 2" and a synchronizer controlling it 2) the poor man's way and just have Pro Tools chase the raw code way to check the code is set up a test session set to 30 fps and see if Pro Tools stays locked or drops out, keep changing the frame rate until it stays locked
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Honestly I don't think you'll even notice for a 3~5 min song. If you have protools chase the tape machine it really won't make a difference. Just write down what you use so if you need to fly stuff back onto the tape it will be in sync. The only way you'd run into a problem, even if you didn't have the TC set correctly, is if you needed to sync to something else. But so long as you use the same settings when putting stuff back onto tape as you did when taking stuff off of tape, the actually frame rate you pick is irrelevant. The only thing that might get weird is pitch. If the PT rig is set to 29.97 and the tape is at 30 fps, the Sync IO might speed up protools by 1% when chasing the timecode. if that happens, you might notice everything sounds a few cents flat when playing back on PT's internal clock compared to when it is sync'ing to timecode. But, technically it shouldn't cause a problem so long as you tune to the track, and not a standard tuner. If the track is a few cents flat...and a singer sings to that, when you sync it back up to tape, protools will play back faster again and speed the pitch of the new vocal tracks up to match the correct pitch of the tape. so again, I don't think you'll even notice a difference.
If there are no automation files or slave reels then there is nothing stopping you re-striping the tape with a known time code.
>>The only difference is 29.97 runs 1% slower<<
Actually, it's .1%, not 1%. Your tape is probably 30 frame, because nobody who striped tapes back then for automation purposes resolved their tapes to video ref, which is the only difference between 29.97 and 30. But if you're going to use video ref, the 30 becomes 29.97 by definition. You can't run 30 and have it be video refed. And you should do it as 29.97, because it makes it easier to deal with potential problems such as dropouts. -Evan Benjamin |
It's all a blur now. Mark |
I'll also try the suggestion in the other forum of trying to read the SMPTE using the SYNC I/O, while the analog machine is on internal "clock". Good stuff jogging the memory. Thanks. Mark |
Depending on the quality of the heads and tape re-striping might cause more leakage of the SMPTE tone to track 23. I'd make some tests on an empty area of the tape.
"The Mackey Big Knob is, you press little button and they can hear through the headphones, you can say whatever you wanted to them without you having to yell." by Tad Donley |
CALM ITU-R BS.1770 What flavor? | Peter Cole | Post - Surround - Video | 4 | 10-09-2013 07:58 AM |
Which flavor of SMPTE | Media Man | Pro Tools TDM Systems (Mac) | 21 | 01-04-2010 11:51 AM |
MTC-To-SMPTE/SMPTE-To-MTC Interface - What do YOU use? | Nawlins | Post - Surround - Video | 5 | 03-20-2008 02:55 PM |
New flavor of Pro Tools | Noiz2 | Post - Surround - Video | 1 | 04-10-2005 10:42 PM |
Back-Up Flavor? | fasttraxx | Pro Tools TDM Systems (Mac) | 5 | 02-28-2001 09:06 AM |
