Old 07-11-2001, 04:02 PM
clutch clutch is offline
Default 50hz hum from surrounds
any word on the 50hz earth hum coming from the surround speakers issue? - it seems to have disappeared from this board.
the hum is mainly prevalent in the surrounds but there is also a little in the center channel.
i'm waiting on a replacement C24 - hopefully coming tomorrow.
in the meantime it's very difficult to accurately mix with this problem. it's drining me up the wall.
have replaced cables, used many different power sources on different and same earths and am convinced it's the output stage of the desk.
is each C24 tested before it leaves the factory floor? [img]images/icons/confused.gif[/img] [img]images/icons/shocked.gif[/img] [img]images/icons/confused.gif[/img]
He used to cut the grass...he was a very nice boy...
Old 07-11-2001, 07:55 PM
jkrebs jkrebs is offline
Default Re: 50hz hum from surrounds
I have the same problem on all of the C24 outs and have tried lifting AC grounds, lifting pin 1's, etc.
I have spoken to Digi several times about it but have not gotten anywhere.
Please post your results about your replacement C24.
Old 07-15-2001, 05:42 PM
[img]images/icons/grin.gif[/img] WOOHOO! [img]images/icons/grin.gif[/img]
just installed the replacement C24 and the surrounds are fine. seem it WAS the output stage of the last desk.
Happy Days! now back to work...
If only we could charge someone for the lost time...
[img]images/icons/wink.gif[/img]
Where are my LE Surrounds? kentgibson Post - Surround - Video 2 11-06-2009 10:47 PM
HRTF and surrounds EQ minister Post - Surround - Video 5 01-07-2005 05:58 AM
New Lifehouse album down 6db @50hz? AE Pro Tools TDM Systems (Mac) 53 02-18-2003 10:59 PM
Nasty 50hz hum removal seandaly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-12-2002 09:38 AM
50hz humm/control24 Tom_Weber ICON & C|24 1 07-03-2001 09:44 PM
