Wiring Question
I'm bringing my synths (typical Roland, Korg stuff) into the C24's line inputs which are balanced. The synths are unbalanced, so I wired the cables hot-to-tip & cold & ground to sleeve and left the plugs going to the line inputs TRS. This got rid of some ground issues & riased the gain I was able to get, but I still find that I've gotta open some of those pre's to the max & still not have enough gain. What are some of you guys doing? Thanks.
Re: Wiring Question
Darla, I was going through the C24 line preamps from my synths, then out of C24 into the 1622. I kept playing with raising & lowering the gain on both the C24 & 1622. I found the C24 pres didn't have enough gain and have a certain coloration which is fine if that's what you want; I didn't want it all the time. The clarity of sound from the 1622 worked best. So I rewired going straight into the 1622. Of course you could increase output gain from the synths. Hope this helps.
Alexycon |
Question about 192 I/O(DB-25 wiring) | maxserg | Pro Tools TDM Systems (Mac) | 1 | 12-07-2005 06:11 PM |
wiring question | 16yearsjeff | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-22-2005 08:48 AM |
wiring question | digitile | Pro Tools TDM Systems (Mac) | 0 | 12-04-2002 03:29 PM |
Wiring Question On HD | the dude | Pro Tools TDM Systems (Mac) | 1 | 02-01-2002 11:22 PM |
another wiring question | ryland b | ICON & C|24 | 2 | 08-10-2001 10:10 AM |
