Old 07-04-2001, 09:36 AM
tomhartman tomhartman is offline
Default C24 F1 Not Working
In 5.1.1, it says that the F1 key will bring the C24 "home," showing the first 24 faders...but not on mine. What's the trick?
When I press the key, it no longer says "Not implemented yet" but it still does nothing....
Old 07-05-2001, 12:57 AM
ashdot ashdot is offline
Default Re: C24 F1 Not Working
Same goes for F10 (also added in 5.1.1).
Actually, none of the new C24 features, such as copy/paste settings seem to work.
Izhar
Old 07-05-2001, 08:09 AM
8bit 8bit is offline
You need to reset your ethernet connection in the peripherals section so that the latest firmware is loaded into the Control 24 then it should work fine.
be well
Old 07-05-2001, 11:11 AM
ianmiller ianmiller is offline
The latter point is right - I thought a new version of PT would load the latest firmware, but it only does this when you go into the peripherals menus and reset the ethernet controllers - worth knowing!
Old 07-05-2001, 11:31 AM
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by ianmiller:
The latter point is right - I thought a new version of PT would load the latest firmware, but it only does this when you go into the peripherals menus and reset the ethernet controllers - worth knowing!<HR></BLOCKQUOTE>
Hey thanks for the tip, guys...I'm on my way...
Digi 002 - optical input not working / only DI channel 1 working Maulden7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 11-07-2013 01:46 AM
Mp3 not working and my key focus e not working vanquished1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-02-2009 09:42 AM
Strike 1.5 upgrade - not working because of iLok-working now gryphondale Virtual Instruments 0 01-27-2008 09:23 AM
digital i/o...working? Not working? ThomCat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-18-2001 08:43 PM
VIA chipset: working/not working Tomek S 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 11-02-2000 07:29 AM
