Old 09-13-2017, 08:19 PM
nate9's Avatar
nate9 nate9 is offline
Default Re: LE vs HD
Does the quality of plugin sound processing increase with hd?
Control24, Digi 002, Rosetta 800, KRK V8's, PT 7.4
Macintosh G5 Dual 2.0 3 gbs ram
Old 09-13-2017, 09:36 PM
YYR123's Avatar
YYR123 YYR123 is offline
No
Daniel
Old 09-13-2017, 09:37 PM
nate9's Avatar
Is it more for track count?
Old 09-13-2017, 09:42 PM
YYR123's Avatar
Default LE vs HD
I would say an older HD TDM system today is about latency - tracking a band and feeding hP mixes right out of the mixer
Native track counts far surpass TDM track counts.
Native processing power surpasses TDM power as well.
But in general TDM still tracks and tracks more stable and with significantly lower latency than a Native FW / USB type of interface
Native = PT12 vanilla
Daniel
Old 09-14-2017, 06:17 PM
nate9's Avatar
I just discovered llm, it works great in pt 11.3.1 Le, hd has less latency or are they the same?
  #16
Old 09-14-2017, 08:55 PM
nate9's Avatar
So your saying that hd won't give me a better sound just the ability to capture more sound?
  #17
Old 09-14-2017, 09:10 PM
YYR123's Avatar
HD gives you
the ability to mix in surround 7.1
Advanced automation modes (nice for sure but not OMG I would pay more for this)
Lower latency via Avid Hardware ( HDX and HDN) and DSP in the case of HDX.
Also Heat.
I think that's basically it....
Also with HD you can run Icon Control Surfaces
Daniel
  #18
Old 09-14-2017, 09:16 PM
nate9's Avatar
I use the 002, I'm frustrated with the sound I'm getting out of it!
  #19
Old 09-15-2017, 06:27 AM
YYR123's Avatar
Default LE vs HD
Yes A/D and D/A is really important
The first time I hooked up my Apollo after running a Focusrite FW interface was EYE OPENING or rather EAR OPENING
THE AD and DA conversion was way superior,
But to run a 3rd party interface you will have to get PT9 or higher.
Apollos are nice, probably about the same io size as the 002.
The twins are nice also, buy as much DSP as you can afford. Quads are the lowest you should go.
Daniel
