Problems installing PT8 (Win)
Heey! I'm trying to install PT8 and this happends:
1. I start the install CD (Tried with and without the mbox2 attached) 2. Opened the folder and clicked Setup 3. Nothing happends for a minute, then this shows up: What to do?! |
Re: Problems installing PT8 (Win)
http://www.sweetwater.com/sweetcare/...-of-pro-tools/ There is a process to installing 8LE Right click the setup icon and click run as administrator Try running in windows compatibility mode: Right click and select windows xp service pack 3 Don't have your mbox 2 connected during the 8 install process The mbox drivers should be installed after 8 is installed. Once you have 8 working run the latest drivers and only connect the mbox when told to do so, not when installing Pro Tools
System Specs: http://duc.avid.com/member.php?u=108915 Audio Reel: http://www.wacc.net/ https://soundcloud.com/13guatamas13 |
Problems after installing on w7 | zevoncss | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-20-2010 03:13 PM |
Problems re-installing LE 7.3 | churchib | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-29-2009 08:28 AM |
Problems installing OS X | stevegalante | Pro Tools TDM Systems (Mac) | 5 | 06-25-2003 10:38 AM |
Problems installing 5.3.1 TDM. | nicksense | Pro Tools TDM Systems (Win) | 4 | 06-24-2003 01:52 PM |
problems after installing 5.3.1. | EL | Pro Tools TDM Systems (Win) | 0 | 09-06-2002 10:37 AM |
