Problems installing 5.3.1 TDM.
I am having a problem installing 5.3.1 TDM software on my PC. Previously I had 5.3.1 LE on my computer, but I uninstalled all that before trying to install 5.3.1 TDM. Whenever I try to install the new software I get a message "You have already installed 5.3.1 LE or 5.3.1 TDM on this computer please modify in Add/Remove programs." Please help me out if you can.
Thanks, Nick |
Re: Problems installing 5.3.1 TDM.
It would appear that you just went in and trashed the program without removing the elements that reside in the system. That is why there is a tool in you OS to remove applications. You might try installing the application after removing everything and restarting the computer
Did you buy some new hardware?
Why are you installing TDM? if you only have a 001 then you cant install TDM. |
Guys,
I believe I correctly uninstalled everything. First I ran the uninstall for PT LE then I removed the hardware. Next, I installed a D24 card and DSP Farm and an 888/24. Booted up the computer again which is running XP Home, waited for my comp to see the d24 and dsp farm, then tried to install the new TDM 5.3.1 software. Thats when I got the error message. |
I believe you need to install the drivers for the cards first. I failed to do so myself the first time, and got nowhere. Then reboot and install PT software.
Problems installing PT8 (Win) | pt8confused | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-30-2013 04:56 PM |
Problems after installing on w7 | zevoncss | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-20-2010 03:13 PM |
Problems re-installing LE 7.3 | churchib | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 07-29-2009 08:28 AM |
Problems installing OS X | stevegalante | Pro Tools TDM Systems (Mac) | 5 | 06-25-2003 10:38 AM |
problems after installing 5.3.1. | EL | Pro Tools TDM Systems (Win) | 0 | 09-06-2002 10:37 AM |
