Is there an objective recording stability test?
I know and have used the Davec test, but I am wanting to test my PT LE/Digi002 Rack/ibook/LaCie Quad drive stability before an upcoming recording session.
I will be recording live, ~ 15 tracks simultaneously and I plan to just let it run for the length of the whole session instead of creating separate sessions for each song. The sets will last about 1 & 1/2 hours each. I can start a new session during the break between sets. I can go in and arm 15 tracks and press record and see how it behaves, but it seems to me that 15 tracks recording silence is not going to put the same load on it that 15 tracks of different wave forms being recorded simultaneously will be. I have done this before using the system drive and recording about 10 tracks at the same time. It worked better than it should have with the system drive, but started throwing errors and stopping during the last 2 sets. Thanks, bilco |
Re: Is there an objective recording stability test?
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
What about this, but actually recording the test tone for 1-2 hours??
The Dverb 2.0 Test Start the computer. Create a brand new 24bit/48k Session on your audio drive for the Dverb test. Open up the system usage window in PT. Then, go to Setup > Playback Engine... > and make sure the RTAS engine: Ignore Errors During Playback/Record(may cause clicks and pops) is NOT checked. Set up your time line ruler for Min:Secs. You want to be in grid mode and set up your grid for Min:Secs and 1 second. Create one mono audio track. Take the selector tool, put it on the 5 minute mark in your audio track and drag this to the start of your session. You will now have 5 minutes selected in this track. Go to AudioSuite > Other > Signal Generator and click on the "process" but. You should now see a 5 minute test tone. Create another audio track and insert 5 Dverbs in all the inserts. Record arm the Dverb track. Click on the track name so it is high lighted white, and hit shift+alt+D then hit enter. Record arm the new track and continue this pattern. You want to be able to record WITHOUT THE TEST TONE BREAKING UP!! Keep adding Dverbs and recording. If the test tone starts to breakup, then delete some Dverbs until you can hear a SOLID TEST TONE for 5 MINUTES. This is VERY VERY important. The test tone has to be 100% solid!!! It's possible......
Mac Pro Dual Quad 2.8Ghz 2008 MacBook Pro i7 2012 OSX 10.8.5 - OSX 10.7.5 Pro Tools 10.3.7 - 11.1.2 6GB RAM Universal Audio Apollo Quad!!! Eleven Rack Focusrite Octopre MKII Yamaha HS80s Rockit RP5 Monitors w/ RP10 sub |
My eleven rack recording test | Idisagree | Eleven Rack | 4 | 02-15-2011 11:30 AM |
Pro Tools LE stability for live recording | digidesigner | VENUE Live Sound Systems | 3 | 06-11-2010 02:48 PM |
Objective Experience as a new Digidesign Customer | svenu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-09-2005 05:23 PM |
Protools 6 stability test | Chris Lambrechts | Pro Tools TDM Systems (Mac) | 0 | 04-24-2003 05:25 PM |
Objective (or subjective) viewpoints - 001 mix on HD? | Bo Walker | Pro Tools TDM Systems (Mac) | 1 | 11-18-2002 06:18 AM |
