Pro Tools "Ghost Notes"
Hello, can someone please help me with this issue? I'm getting "ghost notes" and need help addressing this - what is a "ghost note"?
1. A note that cannot be added: Happens on the very first beat of a measure, and when I add a note it just disappears. 2. A note that cannot be deleted: Also happens on the very first beat, and I cannot delete the note. If I move the note, a "second" note appears that allows me to move it, but the original note is still there in the same place. I attached a screenshot that shows where these issues usually occur, but they also happen when these "thick dashed lines" are NOT present. I have no idea what is causing this, or how to correct it. ANY help is appreciated. Thanks!! Steve |
Re: Pro Tools "Ghost Notes"
Thanks, you mentioned consolidating the clip - how do I do that? I highlighted a clip, but did not see a "consolidate" option. Thanks!
Select the clips, then hit Shift+Alt+3 (PC).
Nice! At first glance it appears to have cleaned it up - THANKS!!
This Forum is becoming a "Ghost Town" | KeyplayerG | Artist Series | 8 | 07-02-2015 02:42 PM |
"Pro Tools quit unexpectedly" when opening (holding "n" no longer fixes it)[RESOLVED] | andrew24c | macOS | 4 | 07-23-2014 07:21 PM |
What's up with all these "Ghost" ilok licenses? | roberts | Getting Started | 10 | 03-26-2014 08:41 PM |
Using "Target Notes Via MIDI" with Pro Tools 10 | CooperCerulo | Tips & Tricks | 0 | 08-13-2013 02:58 PM |
"Ghost" clicks on regions | lode | Pro Tools TDM Systems (Mac) | 17 | 10-12-2010 01:24 PM |
