Old 03-13-2019, 01:43 PM
amscheme amscheme is offline
Default Acoustic guitar mixing
Question for any mixers out there, I have a track that the acoustic guitar is peaking on and at the same time the whole song is lower than the other songs on this project, any advice on how to get the song louder without the acoustic guitar peaking? I have tried a couple basic limiters with not much success. I am running pro tools 10.3.10 and have the WAVES plug ins bundle
Old 03-13-2019, 02:49 PM
Southsidemusic's Avatar
Default Re: Acoustic guitar mixing
Try adding some compression and maybe some eq.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 03-13-2019, 03:00 PM
amagras amagras is offline
Maybe your other songs are too loud.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 03-13-2019, 04:00 PM
DonaldM's Avatar
DonaldM DonaldM is offline
When you say "Peaking" do you mean "clipping"? If its not clipping you might have a couple options. Besides using some compression (the Waves Renaissance Compressor might be a good option here), you could use the clip gain control, section off where the guitar is too loud, and use the clip gain on just that section to pull it back a bit. Another option is to use the Trim plugin to pull it back. You could automate it to pull back are just certain spots.
Good luck!
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Old 03-13-2019, 04:05 PM
BScout BScout is offline
Find better limiters
Find better compressors
Ride (dip) automation levels on any large transient peaks and then lift the whole level up.
Old 03-13-2019, 04:17 PM
The meter actually isn’t even in the red but when I go to listen to it on my phone( since unfortunately that’s how a lot of people will hear it) I can definitely hear the guitar distorting, thanks I will try all these suggestions and I know that renaissance plug in I have not tried yet, thanks again
Old 03-13-2019, 07:09 PM
Can you post a fragment so we can all be in the same page?
amagrasmusic.com
Old 03-13-2019, 08:04 PM
Yeah For sure I’ll do that in the morning
Old 03-14-2019, 04:38 AM
An acoustic guitar is distorting and you're not in the red? What's your recording chain? Maybe you overloaded the input to the mic pre? Or is this an acoustic guitar with a piezo pickup and you're using that to record?
Piezo pickups have a problem known as piezo quack which can be brought about by picking too hard. Also piezo's tend to be sensitive to loading.
Is it even distorting? Might be fret buzz or a cracked brace inside the guitar. I know the latter because my old Gibson B25 has a crack in one of the braces and sometimes a mic picks that up. It might even be strings bottoming out on the frets which would mean the truss rod might need adjustment.
Jack
QAPLA!
Old 03-14-2019, 07:37 AM
I think the problem is picking too hard and maybe is not technically distorting but creating a bit of an unfavorable sound, I am having some luck with some compressors suggested before so I think this one is remedied. Thanks for all the info I will definitely pay more attention to all the nuances next time recording an acoustic, sometimes I’m so worried about other things and aspects of recording I think “ acoustic guitar isn’t in the red, I’m sure it’s fine”
Thanks again for your time
Acoustic guitar .... jeam25 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 40 09-24-2009 06:41 PM
acoustic guitar help kindkind Pro Tools TDM Systems (Mac) 7 02-02-2006 07:36 AM
Acoustic Guitar EQ bigcow 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 17 04-12-2004 04:28 PM
HELP! Acoustic guitar recording and mixing. robbins876 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 28 03-28-2003 06:15 AM
acoustic guitar, which mic? TimOz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 15 08-04-2000 04:41 PM
