Old 06-26-2006, 12:42 PM
WRX07 WRX07 is offline
Default Tape machine with 002
I'm trying to mixdown to a Studer A810 2-track tape machine with Pro Tools LE before mastering...will there be any playback speed issues? which speed should I use on the Studer? Thank you!
Old 06-26-2006, 01:08 PM
Barnabas Barnabas is offline
Default Re: Tape machine with 002
Typically the faster the tape speed, the better the recording quality.
What speed can your mastering engineer work with? He/she should be the main deciding factor in the format (speed) of the tape.
www.barnabas.com Barnabas MultiMedia
Old 06-26-2006, 01:51 PM
minister's Avatar
minister minister is offline
15 ips either 1/4" or 1/2" is the sound of rock 'n roll !!
30ips will give you less bass response.
is your machine clean and calibrated?
for sending to mastering you need to clearly mark the box :
Format and speed (eg 1/2-track 15ips, Tail out)
1k, 10k, 100Hz, 50Hz is the minimum. In that order. You can also add 15k, and a channel check where the 1k starts in the left channel only. The 15k is used for fine azimuth adjustment and potentially to set the head loading for flat response at 10k and 15k
OVU Ref level.
NAB or IEC/CCIR EQ used.
NR type used, if any (We have it all from Dolby A, B, C, SR, DBX 1 & 2, Telcom C4 & HiCom).
Dolby tones if applicable!
Machine type and date.
Track listing.
Engineer's contact details.
Any mastering notes.
Leader between the tones (at tail) and the songs if you can.
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 06-26-2006, 02:06 PM
I ordered it from filmco in Canada, so I'm pretty sure it's been calibrated. It's 1/4'' and for the most part the bands I record won't spring the extra cash for mastering, so I'll mix it to tape then back into PT to do my psuedo-mastering. If I'm just running mixes to the tape for the sound, can I reuse the same tape multiple times? They gave me some Quantegy tape...
Old 06-26-2006, 02:19 PM
minister's Avatar
I ordered it from filmco in Canada, so I'm pretty sure it's been calibrated...
i wouldn't assume that. did they say it was clean and calibrated?? if it is used, then i doubt they bought it, put test tapes on it and adjusted the azimuth and zenith and phase etc... but maybe they did.
i bought a machine from Minnesota Public Radio. you'd think it would be clean and aligned. it was OUT OF WHACK!!
do yourself a favor, find a tech in your area who can set the machine up for you. it is not that expensive. you will also need to calibrate to the Quantegy. GP9?
Tom Hambleton CAS
IMDb
-Starcrash
Old 06-26-2006, 04:36 PM
bassntreble bassntreble is offline
I think you should do some reading before committing anyone's masters to tape. sounds to me like you know just enough to get yourself in trouble. you don't really want to reuse the tape. That is your master!!! I don't care if you transfer it into protools at 192K through apogee's....that's your master.
If you don't know much about refrence levels and how hard to hit a tape, I would really recommend against printing your master to 1/4". IMHO, hitting the input transformers of the machine will get you a thicker sound (what is it about iron and music that's synergistic?) Just using the machine as a sort of "bus compressor" makes for some nice polish on a good mix.
G5 1.8X2/3gigRAM/Mbox/7.4 (retired)
MBP C2D 2.4/4GigRAM/Mbox/8.0.1
iMac i7 3.4/16GigRAM/10.0.1
Lee Blaske Lee Blaske is offline
For the best performance, analog tape decks need constant alignment, cleaning and maintenance. That's one reason why digital recording caught on so fast.
In your situation, doing your own mastering, it sounds like your plan is to just use the tape deck as an effect for a bit of sonic degradation (i.e. rounding off the edges of the sound). In that case, if you like the way it sounds, you're all set. If you're playing it back on the same machine, using the convertors in the 002, and re-using tape so that nothing is archived for the future, things are probably not as critical to you. Have fun with it.
Lee Blaske
Old 06-29-2006, 10:48 AM
Does anyone know of any techs around the Central Valley/Bay Area? I live in Modesto, which is about half way between Sacramento and San Francisco. Thank you for alll the help, guys
Which Tape Machine is Best? Kon Alexiou 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 12-20-2010 01:27 PM
Tape machine Sir Bergersworth Tips & Tricks 4 03-18-2006 05:33 PM
Sync 002 to a Tape Machine sr71rules 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-31-2004 06:24 AM
Tape Machine milesyoung Tips & Tricks 0 08-15-2002 05:30 AM
using with tape machine? Eddie Klebach 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-11-1999 04:55 PM
