Go Back   Avid Pro Audio Community > Pro Mixing > Avid Pro Mixing General Discussion
Old 05-22-2018, 09:27 PM
bektolio's Avatar
bektolio bektolio is offline
Default Waves vs Fab filter
I just recently purchased the waves bundle but the fab filter full bundle looks like masterful software compared to the waves bundles. Any thoughts?
iMac - macOS High Sierra Version 10.13.4 - 32gb Ram - 1 TB SSD - I7 3.6 GHz
Old 05-23-2018, 08:56 AM
Default Re: Waves vs Fab filter
Which Waves bundle?(there are several). I use lots of Waves plugins, but I love the Fabfilter EQ(and its on the master track in every session I do). Fabfilter has a much nicer look(and I like that I can re-size the plugins) but I can't say that either sounds better than the other.
Old 05-23-2018, 12:42 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
I am not going to open a can of worms on this since I'm a "whatever tool does the job best at the time" kind of guy so I will just suggest demoing and making your own decision from actual use
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Old 05-30-2018, 08:28 AM
reidj reidj is offline
I'm an avid (no pun intended) user of both but if I had to pick one package I'd go Fabfilter 100%
Fabfilter ProQ2 is by far more flexible with a better GUI than any individual Waves EQ. In natural phase mode it's hard to beat sonically. Fab's Desser is also probably the most full featured and cleanest on the market and blows R-Desser out of the water. This stands true for pretty much all of their other plug ins.
Waves does have some nice emulations which I use for a bit of character here and there. Scheps73 and NLS find their way into most of my mixes these days. I can't live without their Dorrough meters either.
Old 06-06-2018, 02:41 PM
Extreme Mixing Extreme Mixing is offline
They are both very good. I have to say that I've been using a lot of the Schepps Omni Channel. It certainly has a vibe. Lot's of them actually.
Steve
Steve Shepherd
Extreme Mixing
Old 06-21-2018, 03:44 PM
Jeezer Jeezer is offline
I like some plugs of each maker.
Waves are good as they (Eqs and comps) all pretty much work perfectly with my D-Command's dedicated section, they do good work there. I'm not blown away by their 'analog emulations' as other plug-ins from other companies but plenty of people have used them for years and made big records with them so...
I keep a few waves plugs, some great utility stuff (meters etc), I don't like most of the GUIS on the older stuff, and even the new stuff always has laggy guis, that said I mostly use D-command for mixing so it's only an issue when I'm mousing during setup or in-depth sub mixing of a source.
Fabfiilter = Great surgical eq (Pro Q2) way nicer to use than anything waves has in that realm, and does work with D-Command but a bit less slick, Pro G gate is the best gate for me, Pro DS = highly respected desser, and Pro L2 is one of the best limiters out there. I use all of those in every project along with a handful of waves 'utlity' things like VU meters, sometimes some of their weird plugs like brauer motion, rarely an eq, sometimes a CLA76 comp. I usually prefer slates FG-Grey to waves SSL bus comp (both work great with D-Command), for tape I prefer slate over waves a lot. Other eqs and comps I use (and prefer to all of the above) are ELI Arouser (my goto comp - flexible and great sound/action), PSP E27 (awesome character EQ based on the Avedis unit), Kush/slyfi eqs like Axis (api) and hammer (another great character eq but smooth and subtle). Audified RZ EQ Is also good.
Those 3 eqs are my go tos for any itb work if not printing through my Portico II (Rupert neve) or Api hardware, and the arouser + some comps from smaller makers (fuse audio, audified etc) do most the work so stuff like waves, and moreso fabfilter is reserved for the detailed work or again 'utility' - gating, de-essing, metering... and PRO Q2 if I need surgical (in natural phase mode not zero latency!).
I personally have no interest in full bundles from either FF or waves, they both have stuff I'm not interested in (especially waves which is massively bloated with nigh on 30 years worth of stuff I'd never use nor want clogging up my slick system I run with MINIMAL plug ins!). Less plugs in PT the better for me, faster loading, less crash risk etc.
So I'll pass on bundles, I don't want/need slate's bundle either. Good bundles would be stuff from Soundtoys, Eventide (not all but most of it is cool), and maybe softube… but seriously I much prefer to just pick and choose bespoke pieces from each maker to build my own unique blend of ITB spices, rather than rely on one maker to attempt to make the best of everything.
I'd take Arouser, PSP E27, Axis, Hammer, Pro L2, Pro Q2, slate tape/fg-grey (not VMR I hate it!), Lex reverbs (LXP/PCM), eventide mod/verb FX (Blackhole/H3000/Ultratap etc) over any full waves bundle who imo have never had the greatest sound or GUIS. YMMV
Waves VEQ-4 filter curves? Benny_Cha_Cha AAX Plug-ins 4 02-19-2014 06:42 AM
pop filter hef Post - Surround - Video 1 07-02-2008 12:35 PM
Any good Filter / Step Filter Plug-ins? Jsswtpmp182 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-07-2006 05:01 PM
waves renEQ as a notch filter NOISE!!!! blumediaprojekt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-11-2005 12:43 AM
pop “filter” Fritz Tips & Tricks 3 12-03-2003 08:28 PM
