11 R output signal in Cubase
My recent workflow forced me to move away for a while from PT and compose in Cubase. While I had no problems in setting up Cubase to work as a interface and Rig in Cubase 7 I can't resolve one Issue: When I track a guitar through ElevenRack in PT I can record the processed and clean signal and than continue working, editing, arranging without having the rig output engaged all the time. It means I only hear the rig from my speakers when I want to. In Cubase I do basically the same: I can record a rig preset and a mono clean signal at the same time but I didn't find a way to temporary disable the output signal from 11r when I don't need to hear it. One workaround of course is of course to take down the volume down on the rig settings but this is not what I am looking for. It seems that 11r is active all the time while in PT it somehow switches itself of when not needed? Can this be done in another DAW? Or is this specific to how the Interface is communicating with PT? Help very appreciated piotr |
Re: 11 R output signal in Cubase
I believe this is just how it works with Pro Tools. I don't use other DAW's very often, so maybe I am missing something. I would just turn down the volume, may use the volume pedal or activate the tuner.
There are other guys here that use other DAW's as their main DAW's, they can probably help you better than I can.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
Fast track pro: signal on output 2 while output level at 0 | sbrunot | FireWire & USB Audio Interfaces (Mac) | 1 | 12-26-2013 04:11 PM |
No Input or Output Signal AT ALL! | CapitalJ001 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-26-2006 02:30 PM |
OPTICAL output Digi 002 - no signal | stevevaus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 01-09-2006 02:53 PM |
Clock signal in audio output??? | kooz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-25-2005 10:43 AM |
routing output signal | Dennis Currier | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-27-2003 07:53 PM |
