Have I reached the end of the line with my Mini?
I am currently running iOS 10.12.6 and PT 2018,4 on a Late 2012 mac mini 2.6 i7 with 16gig ram and a 250 apple SSD.
I have kept all of my subscription and support plans up to date and have a PT perpetual license According to Avid's system requirements and compatbilty supported systems info PT 2018.4 is the last supported version of PT for my 2012 Mac Mini. So my question is unless I spring for a new computer have I reached the end of what PT versions my mini can handle? If so am I basicly wasting money on the support and upgrade plans unless I am willing to invest thousands more on a new computor? Thanks TWM
2009 Mac mini 2.53 Ghz 4Gb ram OS X 10.8.5 ProTools 10.3.10- runs rock solid! 2012 Mac Mini 2.6 i7 quad core 16Gb ram 256 SSD OS Sierra 10.12.6 PT 2018.4 its mostly working for me! RME FF800, Presonus Digimax 48K & LT, Central station, KRK Roc kit 8v2, KRK Rockit 10s, a plethora of outboard gear …Too many vintage guitars & amps to list! |
Re: Have I reached the end of the line with my Mini?
https://avid.secure.force.com/pkb/ar...391&popup=true So iOS10.15.3 & Pt 2020.5 while not officially supported are compatible and should be fine on my system? Thanks TWM
It is not iOS but sure it is compatible. I am using macOS 10.15.5 here with zero issues
Is there a particular combination of iOS and PT that you have found is stable and recommend. I know that often the latest versions of OS and PT can have some glitches and bugs that pop up and have yet to be addressed. I am fine being a OS and PT version or two behind if it means less issues. Thanks again. TWM
Stability has more to do with how clean is your platform. I started from empty storage to build my -then- 10.15.4 & 2020.3 and it has been very stable even though I have now updated to 10.15.5 & 2020.5
TWM
No problem. Clean install is your friend, and do not use any migration tool, especially Migration Assassin
Mbox2 mini: is the Line/DI a balanced input? | mbkorn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-09-2011 01:20 AM |
MBox mini line out ? | Kingliar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 04-21-2008 03:36 AM |
Mbox2 Mini & External Preamp Line Level | bilco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 08-16-2007 05:42 PM |
MBox 2 Mini line-input problem | Peter Keuter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-09-2007 01:54 PM |
mbox 2 mini line 2 noise | cida98 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 01-26-2007 11:34 PM |
