PT 2020.5 Windows 10 user
I've been very wary about installing .5, all I see is people having trouble with this install and mainly on Mac. don't see many, if any posts about Windows 10 Is anyone having these dramas with .5 on windows 10? or is more stable on 10
Re: PT 2020.5 Windows 10 user
I'm not having any issues on my end (specs in sig). I'm working on Post from home for work as well as music for myself. Heavy VI's like Omnisphere can still be an issue, but I've moved to hosting those in VEPro.
tg
Mac Studio (2022) M1 MAX / 64GB / 2TB HD / macOS Ventura 13.6.5 / RME BabyFace Pro FS / SSL UF8 + UF1 + UC1 / Roland SYSTEM 8 / Kontrol S61 mk3 / Pro Tools Studio 2024.3 / Nuendo 13 / Reaper 7 / Komplete 14 / Omnisphere / Keyscape / Trilian / V Collection X |
Ok here.
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
Great here.
Excellent so far.
http://douglashood.zenfolio.com/ MSI X99A SLI Plus LGA2011, i7 5930 3.5 GHZ 6 core 12 threads, Kingston HyperX Fury 64GB DDR4 2400MHZ, NVIDIA Quadro K2200, LG 16x Blu-ray writer, Samsung 850 Pro 512 GB SSD for OS, Samsung 970 EVO Plus NVMe M.2 1 TB SSD for samples, four WD Caviar Black 1TB SATA 3 6Gb/s 7,200 RPM drives (audio, samples, video x 2), EVGA Supernova 750W G2 PSU, Corsair Cooling Hydro H100I V2, W 10 Pro, 4 TB WD USB3 external backup, PT 2020.5, IK Sampletank 4 Max, AIR IEP, Wavelab Pro 10, RME Fireface UFX w USB2 connection. |
I was having some minor issues but once I turned off multitasking and I think it was C-state in the bios, per Avid's recommendation, things are smooth as butter. Just go to their optimization page or use one of the general ones available for Protools optimization and you should be fine. These cleared up my VST issues i.e. pops and crackle on playback.
Minor issues here too, some popping and clicking even with all optimizations. Solved by setting Processor Infinity to 7 out of 8 cores (First Core).
Everything great on Win 10 (newest release) here. I do not use video in PT.
Bit of a repost, but for anyone having issues below are the optimizations I find essential. I have not had any "out of CPU" errors or lock-ups with 2020.5. The GUI seems more responsive perhaps. Might freeze my system here for a while. 1) Setting the processor affinity on MY system (see below) is critical. I currently use a setting of FFE for processor usage on my 6 core 8700K. 2) C-states switching and Turbo mode must be off in BIOS. I use a 4.8 GHz all core overclock with a -1 AVX offset. This is 24/7 stable with the cooling listed below. Note, I do not generally test stability with synthetic benchmarks - this is not real world testing. I set up a complex ProTools session and try to make it crash. It only takes a few tries to find the limit of your system. 3) Leave Hyperthreading On. With the Affinity switch, the extra (virtual) cores really improve performance in ProTools. 4) The way you setup your recording session can impact low latency performance. I try to avoid stacking VIs into Auxes with heavy effects. I 'think' this might allow ProTools to more easily parallelize the computations. 5) I always uninstall the Avidlink software and the Software Update App before the first run of ProTools. Maybe superstition. I also always use dual boot installs of Win. My Music Partition never goes online except for monthly Win/Waves/NI updates. With the above settings I can record 16 audio tracks, and 16 midi tracks with Abbey Road Drums, Kontakt Pianos, Kontakt Session Horns Pro, Kontakt Session Strings Pro, Massive, H EQ on each of 4 vocal tracks, H Delay (slap) on Vocal send; CLA Mixhub (lite) on Drum Aux, all at 24/96 for more than 3 hours continuous recording no pops, no clicks, no stops. Never a redline on CPU usage meters. All the monitoring and levels are handled in Protools. With 24/96 the 64 bit buffer gives 'unnoticeable' latency YMMV. Hope this helps someone - Yup, free advise YMMV. ejinbc Hardware Intel Core i7-8700K 3.7 GHz 6-Core Processor; Noctua NH-D15 82.5 CFM CPU Cooler; Asus PRIME Z390-A ATX LGA1151 Motherboard; Kingston HyperX Fury RGB 32 GB (4 x 8 GB) DDR4-3200 Memory; Samsung 970 Evo 1 TB M.2-2280 NVME Solid State Drive - x2 system/samples and tracking; Western Digital Red Pro 6 TB 3.5" 7200RPM Internal Hard Drive - x2 completed work and backup; Gigabyte GeForce GTX 950 2 GB OC Edition Video Card; Fractal Design Define R4 Blackout ATX Mid Tower Case; EVGA SuperNOVA G2 850 W 80+ Gold Power Supply; Motu 1248 on USB2 Software Win 10 (latest); Protools 2020.5; Kontakt Ultimate Complete; Waves Gold + CLA Mixhub; H EQ; H Delay; L2 |
Seems to be ok.
I do hear some cliks, not sure if it because of Battery 4 drums that I have not really used much of in Native Instruments, or PT, but I first started hearing it while I was still in 2020.3 . I opened my system useage window in PT menue and I noticed that on playback, the total useage was only peaking below - 20 and I did not hear ANY cliks. But when in Record, the total draw sometimes spikes to 100 and yes, I do hear an occasional clik/pop. Why? Last edited by ihate100bees; 06-03-2020 at 02:05 PM. |
Try the Affinity switch. Works for me and clicks.
Mbox Pro 3 on Windows 10 with Pro Tools 2020.3 | unkJE | FireWire & USB Audio Interfaces (Win) | 8 | 05-02-2021 01:11 AM |
Pro Tools 2020.5 GUI FREAK OUT on Windows 10 | jrgillam | Pro Tools 2020 | 93 | 04-15-2021 12:59 PM |
Windows 10 - PT 2020.3 - Exporting Video | lowlights | Pro Tools 2020 | 0 | 05-05-2020 02:24 PM |
Pro Tools 2020.3 in Windows 10 | StillHollow | Windows | 8 | 04-19-2020 06:51 PM |
New to 2020 user questions | L-Dogg | Pro Tools 2020 | 4 | 04-08-2020 07:23 PM |
