Old 01-25-2002, 12:53 AM
Michael Klinger Michael Klinger is offline
Default video dropped frames in capture re-re-re visited
Dropped frames on video capture. The age old topic.
I am now using a fuse card on one system (733) and a dc-30 on another (466). The usual setups -- premiere as the capture tool. I've tweaked and tweaked the settings and capture method and created special extension sets, etc. A lot of it is probably voodoo, but while dropped frames in capture are less frequent -- they still happen on both systems -- enough to be annoying (one or two frames over a 50 minute program). And deadlines are tight enough that re-digitizing is neither possible, nor a promise that it won't drop a frame or two on the second try.
So -- any new developments / thoughts on setup to elimintate the nagging dropped frame on capture issue?
Michael Klinger
Tree Falls Post
Los Angeles
(323) 851-0299
[email protected]
www.tfpost.com
Old 01-25-2002, 11:34 AM
JohnGalt JohnGalt is offline
Default Re: video dropped frames in capture re-re-re visited
Make sure Apple Talk is off when capturing. I know it sounds crazy
but that was the culprit for me.
Also, on the Fuse make sure you
have driver ver 2.0.2.
When you once describe a venture as a holy war, you surrender all capacity to judge honest alternatives.
-James A. Michener
Old 01-25-2002, 01:09 PM
thanks for the tips -- I 'm using 2.02 for the fuse and I have a special extension set for video capture that disables all communication including the appletalk and ethernet items.
Michael Klinger
Tree Falls Post
Los Angeles
(323) 851-0299
[email protected]
www.tfpost.com
Video Capture aborted due to doppes frames abx992000 Pro Tools TDM Systems (Win) 0 06-02-2011 12:20 PM
Dropped frames?? zadie Digidesign Hardware & Software 0 03-27-2005 09:17 AM
dropped frames with white flash frames Frank Kruse Post - Surround - Video 6 05-08-2003 10:57 AM
Problem revisited: Dropped frames in video capture Michael Klinger Pro Tools TDM Systems (Mac) 15 11-15-2001 12:44 AM
Dropped Frames in QT pindebraende 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-25-2001 12:26 AM
