Old 06-27-2019, 11:59 AM
Default Re: Bug: Sub paths messed up
Originally Posted by originalscottyg View Post
I don't think the new track dialog creates a bus in the same way that creating a send using the "new track" option also creates a corresponding bus. This is specifically about the system creating a bus and mis-assigning the sub-paths.
That's kind of what I'm getting at - it sounds like there's different paths to creating busses and they don't all work the same although they should. It shouldn't matter how one calls up the routine to do the deed if the coding is properly done (or don't they do modular coding anymore?).
Old 06-27-2019, 10:04 PM
SBP SBP is offline
MacBook Pro 2016 Touchbar
OS 10.12.6
PT|Ultimate 2019.6
Aux 1 created via Send drop-down menu-> New Track
Mostly ok except for Quad. Default path order for 5.1 set to Film in Output page drop down menu. No change when default path order is set to SMPTE. Sub-paths are all correct when creating new path+sub-paths in I/O Setup window.
Same issue with 7.1. Quad incorrect when using Send->New Track method, all sub-paths correct when creating inside of I/O Setup window.
Its really odd that yours are closer to being correct on my system even on PT2019.06 here everything is still a mess. See attached SubpathMess_PT2019.06_OS10_12_06.jpg
And we're on the same OS10.12.6 -Avid HD Omni as the interface
Cheers
Bruno
Old 06-29-2019, 10:38 AM
Originally Posted by SBP View Post
Its really odd that yours are closer to being correct on my system even on PT2019.06 here everything is still a mess. See attached Attachment 11878
Cheers
Bruno
Yeah, at first I thought that maybe they "mostly" fixed it in 2019.6, but I tested this in 2019.5 on the same computer (both are installed), and the results were the same.
I think I was using Built-in Output on my MacBook, just to test this. I know on my Omni at home, I have to do some pretty weird routing/assignments to be able to use 1-2 & 3-4 as H/W Inserts and use 7-8 as my monitor path. I wouldn't think this would affect sub-paths on the bus page, but I guess weirder things have happened.
Cheers!
Scott Gatteño
Old 05-31-2020, 06:00 PM
SBP SBP is offline
This issue remains in PT 2020.05
Create a new path [example 5.1 bus] in the I/O page and select auto create sub paths -Check sub paths you will see all is correct there is no problem working this way.
Create a new path [example 5.1 bus] from the edit window selecting 'new track' as an output and then 5.1 -now look at sub paths in I/O window -you will see a big problem in the 5.0 version (of the new 5.1 bus) the Center is now routed to the Right of 5.0 -any paths created this way need to be sorted out in the I/O page before you can use them properly.
Case Number 03955859
Cheers
Bruno
Old 06-04-2020, 05:24 PM
SBP SBP is offline
PT-240436 Output paths created with "New Track" option have mis-routed sub-paths (7.0.2, 5.1, 5.0, Quad, Overhead)
Bug number above.
"Some paths dropped, only mono and stereo paths supported" LSNY Pro Tools 12 3 08-22-2017 05:40 PM
Stereo HD Native Low Latency monitor paths are a no go with active surround paths? vieris Pro Tools 12 3 07-27-2015 06:07 PM
Question about Sub Paths and Main paths. oulablank 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 08-15-2009 12:15 PM
Understanding Paths Mike62858 Pro Tools M-Powered (Win) 0 04-20-2007 06:25 PM
PFL/AFL paths Robin Reumers Pro Tools TDM Systems (Mac) 1 09-04-2006 11:39 AM
