Soft keys screens Swapped around
After updating to 2020.6 my soft keys screens got swapped around.
It thought I’ve seen an option for swapping screens around between the top and bottom pairs but I can’t find that setting. Is there an option for this that I’m missing? Ps. My soft keys are edited with Eucon layouter if that makes any difference.
__________________ Stefan Boman Atlantis Studios-Stockholm www.parkstudios.se stefan[at]atlantisstudios.se Avid S6 EMI TG12345 Neve 8058 |
Re: Soft keys screens Swapped around
Greetings,
If you’ve customized your own unique set you may simply have to re-load that XML file from Settings > SoftKeys > Load. As a test, you can hit default and it will revert to the factory shipped soft keys. Before you hit default make sure you have saved any current tweaks you’ve made. Jeff Sent from my iPhone using Tapatalk Pro |
Hi Jeff,
I did load that file but everything is on the wrong screens. I have used this XML file on several S6 versions before without this issue. My top two screens is now in my bottom two screens and vice versa. Really strange! Any ideas on how to sort this?
Soft Keys - System Soft Key Display Mode | skilletaudio | Avid S4/S6 | 0 | 09-25-2019 09:07 AM |
Soft Keys | walter rohrbach | Avid S1, S3, Dock and Control App | 2 | 05-11-2019 12:26 AM |
How to Adress Function Keys >F12 from the S6 (Soft Keys) | innenhofstudios | Avid S4/S6 | 3 | 05-08-2019 06:34 AM |
Soft Keys | spoons | Avid S1, S3, Dock and Control App | 13 | 10-21-2016 07:37 AM |
Why no Soft Keys on S3? | jacko | Avid S1, S3, Dock and Control App | 15 | 02-09-2016 07:43 PM |
