Old 07-23-2002, 02:28 PM
Jepse Jepse is offline
Default Help with hardware set-up input gain
From reading posts it sounds as though -10 Dbv is a fairly common setting say for routing an external compressor, in my case RNC. Is this true? I'm using the digi as a mixer. Secondly, what gain setting is optimal when using inputs 3/4 for sound output from Mac G4.
Jepse
MacBook Pro 2019 15 inch 32 GB RAM
Pro Tools 19.6
Apollo X8P
RPQ2 Stereo PreAmp
Some Analog Gear, Various Mics
Guitars, Electric, Acoustic, Piano
Old 07-23-2002, 07:12 PM
where02190 where02190 is offline
Default Re: Help with hardware set-up input gain
Most professional outboard gear is +4 or switchable. Check the manual for specs.
For connecting the Mac outputs ot PT inputs set the input sensitivity to -10db.
Remember that only the 1/2 and monitor outs are balanced+4 when connecting outboard gear and dynamics. 3-8 outs are unbalanced -10 only.
Old 07-23-2002, 08:25 PM
Where. Thanks for your reply. I've assigned my korg 03 module, Boss Drum Machine and Digital Piano to +4 dBu and my Mac output (3/4) to -10. Are you saying the input from the RNC compressor to the digi should be set at +4? There are no specs in the manual.
thanks.
Pro Tools 19.6
Apollo X8P
RPQ2 Stereo PreAmp
Old 07-23-2002, 11:27 PM
thanks.
<font size="2" face="Verdana, Arial">Check their website, but my guess would be yes it is +4.
Input gain uneven nyronack1@live.com FireWire and USB Audio Interfaces (Mac) 2 04-03-2013 05:43 AM
PT LE Internal Input Gain? GrimCoffee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 37 07-02-2005 02:52 PM
help (002) - Input Gain ?! Hadjipita 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 11-06-2003 12:06 PM
Digi001 input gain does nothing...Why? Blind Dog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 11-15-2002 09:55 AM
Input Gain Confusion bassmac 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-18-2001 07:48 AM
