Old 10-17-2001, 10:27 PM
bassmac bassmac is offline
Default Input Gain Confusion
If I understand this correctly, (which isn’t likely) according to the Input Gain setting for analog inputs 3-8 in the Hardware Set-up, a +4 signal should be set to -14db. Does that then equal a Odb input signal?
Supposing that’s true, there doesn’t seem to be an input setting adjustment for optical inputs, so if I am entering ProTools directly from an A/D converter via ADAT with a +4 input, should I then record my signal at -14db on the mixer meter to archive a 0db signal?
[img]images/icons/confused.gif[/img]
Old 10-18-2001, 07:48 AM
lamp lamp is offline
Default Re: Input Gain Confusion
I think you are correct about setting a +4 siginal at -14 in the setup window, for the anolog inputs. If you are talking about adat type optical or lightpipe output levels from a convertor, mixer ect. they have a standard level and protools sets it automatically for you. No matter what your source signal is, analog or digital, set your mixer screen faders meters around 0. peace.
digi 002 input gain dashlogan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 04-24-2015 12:02 PM
Confusion about analog input levels! Terry Wetzel Windows 1 12-21-2013 05:25 PM
help (002) - Input Gain ?! Hadjipita 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 11-06-2003 12:06 PM
INPUT GAIN behind speakers pk_hat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-12-2003 05:15 PM
S/PDIF Input Gain rfreeman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-17-2002 08:34 PM
