Old 12-10-2017, 07:03 AM
jsbach jsbach is offline
Default Can the "Default Output Bus" be set to multiple output pairs?
When I create a new track, I would like it to be routed to both Out 1-2 and Out 3-4.
However, in I/O Setup, I seem to only be able to select one output pair at a time under the "Default Output Bus" dropdown menu. Control clicking a second output pair doesn't appear to work in I/O Setup.
Is there any way to accomplish this?
Old 12-10-2017, 07:10 AM
john1192 john1192 is offline
Default Re: Can the "Default Output Bus" be set to multiple output pairs?
do it on the track you wish to output to up to 3 different outputs .. not in I/O setup ..
it is in the manual that no one reads
OS 10.12.6 for PT 11.3.2 & 12.4 & above
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.12.6 - PT 12.4 & above
lynx AES16e-SRC & Aurora 16
Artist Transport & iPad - Pro |Control - EuCon 3.7 (older Euphonix Branded MC Transport)
Old 12-10-2017, 07:45 AM
Thanks. I did read the manual.
I was trying to figure out a way to have it happen automatically every time I create a new track because I want all of my tracks routed to multiple outputs. That's why I was looking for a way to do it in I/O setup.
It is tedious to manually create the routing every single time I create a new track.
Old 12-10-2017, 08:00 AM
why don't you create a blank session and make all the track types with routing you want to use, then just import session data from that session .. could work
Old 12-10-2017, 08:55 AM
Drew Mazurek's Avatar
I haven't created a track from scratch in 20 years.
www.drewmazurek.com
Old 12-10-2017, 09:27 AM
EGS's Avatar
EGS EGS is offline
I know, right? Once you learn a few workflow shortcuts like this, the old joke description of "Slow Tools" will never apply !!! For quick setups, I store templates of various scenarios I find myself needing.
Desktop: PT 2019.10 / Win 10 / GIGABYTE GA-X58A-UD3R / i7-980X hex @ 3.9GHz / 32GB / Focusrite LS56
Laptop: PT 10 / Win 7 / HP ProBook / i7 quad / 8GB / U-PHORIA UMC1820
Legacy rig (works): PT 5&6 / MAC G4 OS9&OSX / DIGI001
Info/Services link
Old 12-10-2017, 11:01 AM
For mixing/mastering I agree, but for production/songwriting I still find myself often needing to create tracks from scratch.
I could probably make better use of templates there too as suggested, however if there is something else obvious that I'm missing it would not be the first time!
Any "downside" to routing to multiple output ports? jsbach Pro Tools 12 8 02-22-2017 10:50 AM
"No output device selected in Studio Monitor Express, using Default Output"?? Focuret Pro Tools 10 4 01-11-2014 03:31 PM
how do I split stereo output to multiple stereo output pairs? hokuspocus Pro Tools TDM Systems (Mac) 5 04-05-2002 08:34 AM
Methods for sending mix to multiple output pairs tld Tips & Tricks 2 02-26-2002 06:35 PM
Using an aux to route to multiple output pairs tld Tips & Tricks 6 11-12-2001 07:18 AM
