Old 12-10-2017, 02:53 AM
vudoo vudoo is offline
Default going from 12.6.1 to 12.8.2 questions
Hi all,
Could not find a definitive answer from the manual so i thought i post my questions here.
I want to install the latest PT 12.8.2, i'm using 12.6.1 at the moment:
1- Do i need to uninstall 12.6.1 prior to installing 12.8.2 ?
2- I'm using a DAD interface connected to my HD thunderbolt, since i don't have any Avid interface, i assume there's no need to install the Avid hardware drivers, correct ?
3- How is 12.8.2 working out for you guys ? (i'm on a nMP and Sierra)
Thx
Old 12-10-2017, 07:06 AM
john1192 john1192 is offline
Default Re: going from 12.6.1 to 12.8.2 questions
Originally Posted by vudoo View Post
Hi all,
Thx
1) rename Pro Tools 12.6.1 (only works on a mac) for example "Pro Tools12.6.0.585" and then install the new version ... as long as you rename you can have multiple versions ..
2) not sure .. not on HD
3) fine for me .. not so fine for others ...
OS 10.12.6 for PT 11.3.2 & 12.4 & above
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.12.6 - PT 12.4 & above
lynx AES16e-SRC & Aurora 16
Artist Transport & iPad - Pro |Control - EuCon 3.7 (older Euphonix Branded MC Transport)
Old 12-10-2017, 07:08 AM
jjnssn jjnssn is offline
1. I would. For me on a Mac book pro, over write with 12.8.2 caused a lagging GUI. I delete everything along with cache preferences workspaces plists, etc.
2. I don’t know, I just run the main installer. I believe if installed the HD driver it shows up under a folder called HAL in under Mac/library/audio/HAL and I don’t see it on my system. I use UAD Apollo units.
3. It seemed to work well on Sierra for me, I am on HS now.
I always create an image of my drive before updating. That way I can go back more quickly if something goes wrong in the process.
____________________________________________
W10 Pro / X99 / E5-1650v3 / 64GB ECC / nVidia P1000 / ASUS TB3 AIC
PT HDX1 / OMNI / HD IO 16x16 / 11R / Kontakt Kontrol S49 / Artist Transport and Mix / UAD OCTO Satellite, Apollo Twin MKII &, x8P Thunderbolt
[Late 2013 10.14 MacBook Pro]
fruity loops in pro tools question...not regular rewire question nutrinoland 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-23-2010 01:39 PM
quick question - Mbox Mini question - i forget JRup 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-18-2009 03:55 PM
General Venue Automation Question - (Maybe dumb question) TwoPort VENUE Live Sound Systems 5 12-21-2007 03:41 PM
Chipset Question/Hard Drive Question andrewkstone 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 07-26-2006 09:15 AM
