Old 12-08-2017, 06:31 PM
Bob L's Avatar
Bob L Bob L is offline
Default Re: Cpu usage problem with 1 track
Originally Posted by Southsidemusic View Post
He should be able to have any number of GB cache without having these problems. Something is amiss here and I still think it is a plugin issue.
Respectfully, running an 8 GB machine with only 5 GB available for system tasks would seem to be problematic. Note that the published spec is now 16 GB, 32 GB or greater recommended.
Sure, it could be a plugin. The OP should eliminate that as a possibility using the usual method (everything to "Unused Plugins" folder, add back a few at a time after rebooting, etc).
The question of what system drive is in the 13" MacBook has not been answered. If it's a 5400 rpm spinning drive, that would certainly be an impediment.
Further, I just checked the hardware specs for 12 Vanilla and they don't even mention MacBooks.... "Pros" and "Airs", but not plain "MacBooks".
Bob
"Without a song,
The day would never end..."
Old 12-09-2017, 05:08 AM
why_vincent why_vincent is offline
And right you are, I put them in unused and now it is working. Though it would be enough to simply not use the plug-ins but apparently not. I'll start the process of finding which one it was now. Stort tack!
Btw I should have written Macbook Pro and yes, 3 Gb is crazy overkill but I just wanted to make sure that Normal wasn't causing the problem since I have seen a couple of threads suggesting a fixed size instead of Normal.
Old 12-09-2017, 08:31 AM
john1192 john1192 is offline
ah, we did not have all the info up front .. thank you for adding that .. this happens a lot that we can go in the wrong direction due to lack of information ..
please post back when you find what plugin that was NOT being used BUT stil in your PLugins Folder .. this i see as an issue with PT - plugins causing issues when just IN YOur Plugins Folder !! this needs to be documented and addressed ..
thank you john
OS 10.12.6 for PT 11.3.2 & 12.4 & above
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.12.6 - PT 12.4 & above
lynx AES16e-SRC & Aurora 16
Artist Transport & iPad - Pro |Control - EuCon 3.7 (older Euphonix Branded MC Transport)
Fast Track C400 Win CPU usage with drivers version 1.1.5 and 1.1.6 Leremorth FireWire and USB Audio Interfaces (Win) 7 08-25-2014 04:49 PM
Bounce track to save system usage? sb_stefan Pro Tools 10 6 03-19-2013 01:06 PM
cpu usage error with single track eror -6104 Rowdyb 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 05-24-2007 09:34 AM
CPU usage problem clayclay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 06-19-2006 09:03 AM
CPU 100% USAGE PROBLEM...please help YOUNGMOESES 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 12-19-2002 10:09 PM
