Old 12-27-2010, 08:57 AM
Meads Meads is offline
Default Motor Noise
I just unpacked my new MC Mix and played around a little, and I am pretty annoyed by that constant motor noise. It's coming from one fader only, and it comes and goes as it pleases.
Is that a common issue, or should I return it and get another one?
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Old 12-27-2010, 11:52 AM
Venture Studios Venture Studios is offline
Default Re: Motor Noise
unfortunately both mine do the same thing now and again.
Old 12-27-2010, 12:04 PM
Okay, thanks for your input. This at least means it's a feature not a failure, and so I'll keep it (grinding my teeth considering what it costs. For 1000$ you shouldn't have to deal with sth like that.).
Maybe a new firmware will take care of this issue? Pretty please, Avid...?
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
Old 12-28-2010, 10:12 AM
soundworx soundworx is offline
Have the same thing and it seems that a certain production run exhibits this kind of thing. Had a representative here and he had a different MC MIX to test; motor noise was practically non-existent...
Waiting for replacements...
Old 12-28-2010, 10:22 AM
Well, what does that mean for people who don't have Euphonix personnel visiting their studio?
I struggeled to get a quiet control room, and now I have a device right in front of me, that makes more noise than the MacPro which I banned from this room.
It's ridiculous, isn't it? I like the controller very much, but it is really (and I can't stress enough how much) disturbing my working.
I already contacted Euphonix on that, but didn't get a reply so far. If it's a manufacturing failure, and they were able to resolve it, then they should provide customers with functioning devices, taking back the noisemakers.
I mean, it's not that the buttons are lid differently or something one could live with. It really gets in the way of my work, when I do atmospheres for instance.
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
Old 01-01-2011, 03:26 PM
robertg robertg is offline
I have the same problem and am going to call them on Monday... you probably just didn't get a response yet due to the holidays.
Old 01-01-2011, 03:29 PM
I talked to my dealer about that, and he told me that in the middle of january they are getting a shipment of the new revision. He said he's going to replace mine. We'll see if that helps.
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
Old 01-01-2011, 06:44 PM
V314 V314 is offline
I'm wondering if anyone's heard more about this? I have a MC Mix, I here some motor noise, usually it happens just for a moment- almost as if the fader is just trying to settle into it's position/placement after moving, then usually goes away within a couple seconds. .. or if I tap the fader, it helps it fall into position then goes away.
Just wondering if it might get worse over time, or if it's gotten better with the use of EuCon in PT9.
Thx
Old 01-01-2011, 06:56 PM
I'm using it with PT9 and Eucon, and it is like you say - but it doesn't stop after a few seconds, but it literally goes on forever. When I tap the fader it stops. But it's coming back after a while.
And I narrowed it down to one fader. It's only the second from the left that behaves that way.
iMac Pro
- MacOS 10.14.6
- C|24 | S3 | Dock
Old 01-02-2011, 01:39 PM
Interesting, my 2nd fader also takes longer to settle into position. The others usually snap pretty quickly, but that buzzing noise is present on all of them with slow movements.
The fader issue could be a fluke, but the decision to use cheap encoder knobs is very, very disappointing to me. They do not turn smoothly when slowly moved. I have hardware synths and am used to a fluid response. Even the cheapest analog mixers have good knobs. For over $1000, what a big letdown.
My only theory is that there were rounds of cost-cutting during the development process of the product. I know that the Mc Control 2 has better knobs, I wonder if it would be possible to get that improvement with the Mix.
CHUD, fixing ADAT XT sync, and motor noise? Yontz Sucre 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-09-2004 05:31 PM
Attn: Drumkit from Hell experts: noise noise noise Smelt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 07-30-2003 07:31 AM
Motor Mix EvilD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-24-2002 11:10 AM
I'm using the O1V as a motor mix but... Dead River Studio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-18-2001 02:31 PM
001 and motor mix Notefarm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 10 07-08-2001 10:35 AM
