Oh, I thought this would be a Pro Tools update, not EuCon. I actually had the same problem with PT8 and Control24. Last time I remember mix/edit windows follows bank selection working was 7.4 with Command8.
UAD Apollo x16, UAD Apollo Twin Duo, UAD Octo Thunderbolt, Mac Mini i7 2018, Reaper DAW, Presonus Faderport, Arturia Beastep for DAW control, Former Pro Tools HD user (from V7 until V12.6). |
please please please fix this.
I just added a tip about this on another thread, but I'll repeat it here too. There isn't a preference to select it to behave that way automatically, but if you hold "Control" (either with the "Control" modifier on the softkeys of your Artist Control or your keyboard) and select your track from the surface, the Mix window will bank that track into view on the screen. Not ideal as you need 2 hands to do it, but it works and you don't have to scroll around with your mouse.
![]() Quote:
So, if you're on the Pro Tools email list you'll get a notice when an update is available - it's will be in the release notes. |
![]() Quote:
#16
Hi, good to know we can use the soft keys for that. Could you give a brief explanation of how to program that? Would be nice
![]() Kind regards Mark
Mac Pro 2010 3.66 GHz six Cores, HD Native, 192 I/O, Avid Dock, Artist Mix and Pro Tools Ultimate Mac Pro 2008, RME Fireface, Pro Tools 12, Euphonix MC Control |
#17
![]() Quote:
In the 'command' list on the left, select 'key' from the 'Add..' drop down. If the soft key already has a command either delete it first or, if it's already a 'key' command we'll just reassign it. Once you have 'Key' selected under 'Type', in the right panel press the Win/Cmd button to enable it (no other button should be enabled), then type an '=' sign into the white bar below it. This will emulate the Cmd+= shortcut to switch between Edit/Mix. Close that window and the EuCon Settings window, then switch back to Pro Tools and save your session. You should now be able to touch that soft key to toggle between Edit/Mix windows. |
#18
Thanks, I hoped it could cure the bank switch problem as well. My fault, I should improve my reading.
Kind regards Mark
#19
Its all about the bank selection as per original post.
Toggle between Edit/Mix is fine and great for those with MC Control to assign soft key. But the mix window follows bank selection not working is still a major pain. I just got an email from Euphonix side of things saying its still a protools problem. The option is there in the preference panel but does nothing. It works when using the 2 MC mix's with HUI in PT9 (EUCON 2.5.4). I'm just bummed that they got rid of Eucon HUI for PT9 from 2.5.5 because 2.5.4 is buggy and crashes when you grab a few faders at once. But its better than needing to grab the mouse to scroll every time you bank a page. Just hanging for them to fix this. On a side note... I noticed with multiple MC Mix's (lets say 3=24 faders) when using hui, you only need to bank once to go to the next layer ie. channels 1-24 to 25-48. when using eucon you need to bank 3 times to get there. Most digital mixers or control surfaces I've used banks by the number of faders you have. It would be great to have this as an option in Eucon. Eg, bank by 8 or bank by number of units. this would be cool. |
#20
![]() Quote:
Good tip but yeah, you're right about the 2 handed operation being not ideal. There is a preference to select in protools. 2 actually if memory serves me labeled "Edit window follows bank selection" and Mix window follows bank selection". Its a bug but unfortunately has not been fixed in the last 3 protools updates. |
Edit Window Follows Bank Selection. Edit Window Follows Bank Selection. Edit Window.. | Focuret | Artist Series | 17 | 01-18-2014 04:53 AM |
Mix Window Follows Bank Selection - Artist Mix | HowlingWolfStudio | Pro Tools 11 | 4 | 01-17-2014 10:48 PM |
AVID, How can you STILL NOT HAVE FIXED "Edit/Mix Window Follows Bank Selection"??? | Focuret | Artist Series | 33 | 07-09-2013 08:31 AM |
Whoever gets PT11 first, please post if "Edit Window Follows Bank Selection" is fixed | Focuret | macOS | 0 | 04-07-2013 07:08 PM |
Avid seriously, when will the Edit Window Follows Bank Selection function be fixed?! | Focuret | Pro Tools 10 | 1 | 11-23-2012 03:04 PM |
