Old 04-22-2010, 09:42 AM
jmtayloraudio jmtayloraudio is offline
Default C/24 ethernet connection
Our brand new C/24 keeps loosing communication with Pro Tools. The connector on the back panel of the C/24 does not click and seat firmly. If I snug it up I get a green com light and a flashing activity light. Then I'm allowed to re boot the connection in the perphs. Anyone having the same trouble? Is there a fix for the jack? This is a cross over cable yes?
Old 04-22-2010, 05:43 PM
Default Re: C/24 ethernet connection
Sounds like you need a new Ethernet cable. One reason some cables don't seat is because the little nubbin on the cable connector is either missing or of an odd size. And as to whether it's a crossover cable or not depends on whether you're going through a router or direct to the computer. Consult your manual for which you need. And make sure you're using a proper Ethernet cable and not a cheapy phone system cable.
Jack
QAPLA!
Old 04-23-2010, 05:07 AM
DetroitT's Avatar
DetroitT DetroitT is offline
I noticed on a newly delivered Mac Pro that the Ethernet connector (Female) was easy to not catch. Although a firm push-n-wiggle did catch it.
Old 04-23-2010, 11:06 AM
Scott Goldberg Scott Goldberg is offline
I would follow the previous poster's advice and get another cable. They are not at all perfect and the intermittent disconnect will mess up your communications.
Scott Goldberg
Gold Recordings
http://www.goldrecordings.com
Artist Control / Ethernet Connection and Noise Problems lberrios1962 Artist Series 8 05-04-2012 09:20 AM
Control|24 losing Ethernet connection Echo studios ICON & C|24 1 04-12-2004 05:17 PM
Control|24 losing Ethernet connection on TDM/XP Echo studios Pro Tools TDM Systems (Win) 2 04-10-2004 09:07 PM
No Ethernet Connection? Mark McCabe ICON & C|24 0 09-25-2003 12:44 PM
control 24 and ethernet connection ianmiller ICON & C|24 3 03-02-2002 12:24 PM
