Old 04-10-2004, 11:04 AM
Echo studios Echo studios is offline
Default Control|24 losing Ethernet connection on TDM/XP
Hey all,
I've been experiencing some Ethernet connection problems using the C|24 for long sessions.
Sometimes, when mixing and using the board functions a lot, the session goes into an endless audio loop so i have to STOP and then the C24 lights freezes for a few seconds and then the board goes OFFLINE..
After that an error msg appears in PT saying " Could not establish Ethernet Conncetion - PLease power down and restart the Control24, etc etc".
So i have to go into the setup/peripherals menu and the uncheck and then check back the 10/100mbits integrated network controller in order to rescan the ethernet port, select my C24 and then re-enter the session to continue my work.
This seems to happens more often when i'm using a lot of RTAS instances, big sessions or that my CPU usage is set at more than 80% in PT.
My system is as follows:
PT|24 MIX+
Intel P4 2.52ghz
ASUS PC4800-E Motherboard with integrated network controller.
1GB DDR
(4) 10KRPM Cheetah's hooked on Adaptec UW controller.
Anyone having these kind of issues..?
1. Is that a C|24 hardware problem/failure?
2. A bad Ethernet cable? (It was bought direct from Digi)
3. A slow computer...(!)? or too much CPU usage?
Thanks for any inputs,
PT HDX2 / Ultimate / D-Command ES 24 w/ edit pack
MP Dual 3.66mhz ( 6-Cores) / 32GB / SDD 8TB
OSX Sierra 10.12
Dan Desilets
Mix/Mastering Engineer, Guitarist, Composer
New Website live @ www.sublimesoundstudios.com
Old 04-10-2004, 03:56 PM
feliponk's Avatar
feliponk feliponk is offline
Default Re: Control|24 losing Ethernet connection on TDM/XP
Could be your integrated network adapter. Do you have the chance to try with a PCI adapter?
Felipe Gonzalez A.
Avid ACSR Elite
Dante Certified
http://felipousismix.wix.com/felipousismix
Custom Mac Pro OSX Sierra | Windows 10 Pro 64 | ProTools HD 2019 | Pyramix XI | Merging HAPI ADA8 | MBox 3 | UAD Quad PCIe | Avid Artist Mix | Kali LP-6 | Presonus Temblor 10 | Universal Audio, Slate Digital, McDSP, Fabfilter, Plugin Alliance among other plugins
Old 04-10-2004, 09:07 PM
Will definitely try to install a PCI networking card and see what happens..
Thanks for the cue,
Dan
OSX Sierra 10.12
Dan Desilets
MC Control losing connection Trazan Artist Series 7 07-27-2012 05:57 AM
Control 24 losing connection KrisHeinold ICON & C|24 4 12-06-2010 12:22 PM
Control|24 losing Ethernet connection Echo studios ICON & C|24 1 04-12-2004 05:17 PM
control 24 losing connection w PT firedog57 ICON & C|24 3 02-02-2004 09:23 AM
control 24 and ethernet connection ianmiller ICON & C|24 3 03-02-2002 12:24 PM
