Old 06-07-2013, 10:16 AM
sb_stefan sb_stefan is offline
Default Auto tune in pro tools?
If I have a vocal track, and I want to adjust one singel word (1 note) in the track, what is the best and easiest way of doing that?
For example, if a vocal note is supposed to be a D but the singer hit a Db, can I somehow just highlight that part of the waveform and type in the letter D somewhere?
Old 06-07-2013, 10:18 AM
sw rec sw rec is online now
Default Re: Auto tune in pro tools?
Highlight that note and use the Audio Suite pitch shift and raise it 1.059% (that's half a step.)
Old 06-07-2013, 10:21 AM
Ok, so the only way is to do it by ear? I'm thinking the original note might be slightly below or above a Db. There's no way to make the software turn it into a D no matter what it was in the first place?
Old 06-07-2013, 10:54 AM
Philthy Philthy is offline
Originally Posted by sb_stefan View Post
Ok, so the only way is to do it by ear? I'm thinking the original note might be slightly below or above a Db. There no way to make the software turn it into a D no matter what it was in the first place?
Enable "target note via MIDI" in Autotune. Create a new MIDI track with the output set to that instance of Autotune. Play or manually enter the D at the same time as when you want the pitch corrected. Autotune will only change the pitch when you send it MIDI data... the rest of the time it's basically in bypass mode. You have to play the pitch correction in the correct octave, otherwise it will sound really goofy.
Phil Mann
Silk City Music Factory - CT Recording Studio
Old 06-07-2013, 11:15 AM
Another way you can do it is use autotune in audiosuite and define the scale as only being the corrected note you want. Process a bigger area than you need and then edit in the boundaries to get a clean sound.
Phil Mann
Old 06-07-2013, 12:21 PM
Other options: separate the word and use Elastic Pitch to correct it(a bit of trial&error, but it can work). Or use Melodyne(you can transfer in as much or as little of a track as you want). Certainly, Autotune can do it, just tossing out other ideas
Old 06-07-2013, 04:46 PM
pianosound pianosound is offline
One more option that I have found to be quick & easy is Waves Tune. Even Waves Tune Lite does a great job! Select a region, then with your mouse move any part of the sound,, all of a note, small part of a note, or a whole phrase up or down. A great plug in when you have a soprano that constantly goes sharp at the end of a phrase!
Mike
Intel Core i7 4790K 4.0GHz | Asus Z97-Pro LGA 1150 Intel 6Gb | Corsair Vengeance Pro 32GB DDR3 2400 | Asus GT640 Silent 2 GB GDDR3 | Samsung 850 Pro SSD's, WD Caviar Black HDD's | PSU Corsair 750W ATX12V | Windows 10 | Presonus Studio One | 003R PT's 12.8 | Waves Platinum | Ivory/Piano | Berlin Woodwinds, Nocturne Solo Violin | SPITFIRE Solo Strings | EastWest Hollywood Strings, Brass, Pro Drummer, and Stormdrum 2 | VSL | Vienna Ensemble Pro | M-Audio Code 61, FaderPort 8 |
Auto Tune in Pro Tools 11.1 Becharax Pro Tools 11 3 01-02-2014 07:56 AM
Auto-tune 5 has issues with Pro Tools 10 TheLastHobson macOS 3 11-20-2011 02:54 PM
Pro Tools 8 Won't Recognize My Auto-Tune Truth Himself 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-18-2009 01:36 PM
Pro Tools 8 adds Auto-Tune? dougied 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 13 11-20-2008 08:09 AM
Auto-tune 3 VST with Pro Tools LE 5.0.1 kvinson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-25-2001 09:21 AM
