Which drum program to buy?
Just a question. What would be the best drum program/good drum samples to work with that is reliable and works well with Pro Tools 8.
I record drums and use structure and boom for most projects. But I would like something that sounds great that you can program down to where abouts you are hitting on a snare to how close you are hitting on the hi hat bell etc. Think Alternative/Industrial/Rock style. Cheers. |
Re: Which drum program to buy?
-------------------------------------------------- Why do people keep running over a string a dozen times with their vacuum cleaner, then reach down, pick it up, examine it, then put it down to give the vacuum one more chance? |
Steven Slate Drums sound GREAT...it's just too bad they use the Kontact player.
Never had any problems with my system 'till I installed Kontact...when I'm using it my system is a little unstable Plus you have to use midi files to trigger it, no built-in player like BFD2, or Strike. For in-depth tweaking, BFD2 is definitely the way to go
003r/i7-930/LE 8.0.1 cs2 on xp |
I've had no issues with the Kontakt Player 3.5 & SSD. Thankfully
So BFD2 is the way to go it seems. What is the best one to buy? Does the stock standard come with most of what you need?
I hope BFD2 plays nicely with PT8. BFD1 and PT were never good bed-fellows.
EZ Drummer and Superior Drummer are also very good.
That's my 0.04
BFD2 plays very well (version 2.1.0.47) with PT 8.0.
Ha Ha I'm not sold. :P
But like I said, I want something that can produce great results for Alternative/Industrial/Rock, has some decent in depth tweaking, great samples and works good with Pro Tools 8. What is Strike like? I haven't used it. |
Drum Program With New Rig | jack s. | The Drum Room | 8 | 06-15-2010 12:12 PM |
Drum Program for 001 | jaykers | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-19-2007 04:38 AM |
Best Drum Sequencing Program for PT? | VanDerGraf | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 04-28-2006 07:28 PM |
ANY Drum Programming program that will do.... | s0nguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 19 | 05-03-2004 07:53 AM |
A Good Drum Program | rope | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-22-2002 10:29 AM |
