Re: What's the most stable Mac OS to run PT12?
Was until a few days ago when I applied the combo updater for 10.12.3 and noticed no change at all.
Is 10.12.3 officially sanctioned? About to slowly build a new partition here.
cheers Mike Aiton BSc (hons) Audio Consultant, Dubbing Mixer/Sound Designer & Journalist BAFTA member IPS member ---------------------------------------------------------------------- www.mikerophonics.com |
http://avid.force.com/pkb/articles/e...tibility-Chart But I always jump in and test ahead of time. |
Thank you
Another vote here for 10.12.2. Been on it a month now and my experience is the same as Drew's. I used to get the random freeze on Mavericks but none since the fresh install of Sierra.
The only issue I'm having is GPU related. Twice when launching Resolve it has told me the GPU memory is full and once I actually had visible graphic corruption on the screen. Resizing the desktop solves this problem but it comes back a week later. Not sure if it's CUDA related as there have been two CUDA updates in the past month.
10.12.3 running perfectly here with PTHD 12.7
Matt McKenzie-Smith mattrixx.net SourceConnect - mattrixx AVID Collab user - mattrixx MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01 |
From all the versions of PT12 and OS I must say PT12.7 (HD) and Mac OS10.12.3 has been the best. still far from perfect if your running the video engine which in my opinion still sucks and is still full of problems.
I work mostly on OS10.8.5 with PT10 (on the same machine) and is lightning fast compared to PT12. I just get so fed up with the the stupid crashes and very leggy behaviour of PT12 An other great alternative is Nuendo, I've use it most the time if I don't have to deliver to a stage where the mix in PT. that being said Nuendo outputs a actually working AAF you can import into Pro Tools no problem with all your Clip gain, Volume levels and fades. on sale now https://www.steinberg.net/en/shop/bu...&et_sub=Nuendo 7 |
Finally got some imaging software and cloned the C drive last week. Amazing how easy it was to create an image on another SSD to experiment with! I loaded 12.7 and put it through the paces, deleting/uninstalling this or that, all with the confidence of having the home drive to go back to. A virtual PT playground.
Pro Tools 12.4 HDN, PCIe, Omni & Digi 192 ASUS Sabertooth, Intel i7 3820 3.6Ghz 32 GB 1600Mhz Corsair RAM SSD 500GB Samsung WIN 10 64bit |
Opening oversized PT12 HD session in non-HD PT12? | mjpatey | Pro Tools 12 | 6 | 01-10-2017 09:25 AM |
Is there an upgrade from PT12 to PT12 HD? | Hot Banana Studio | Licensing & Accounts | 16 | 11-21-2015 12:13 PM |
PT12 and PT12 HD surround? | theom | Pro Tools 12 | 17 | 10-12-2015 09:27 AM |
is 7.1 or 7.2 more stable on HD3 G5? | MixerGuy | Pro Tools TDM Systems (Mac) | 0 | 10-25-2006 11:03 AM |
Most stable on the new G5 | MR808 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 03-28-2004 11:45 AM |
