Old 08-08-2009, 12:28 PM
SaturnSound SaturnSound is offline
Default Axiom Hypercontrol vs D Command
I discovered a conflict between the D command and Hypercontrol. The transport controls work fine but it forces the control surface into an 8 fader bank mode I can't figure out how to undo. In MIDI controller preferences it defaults to "8 channels" with no options for other values. When I select a fader on the controller outside of the Hypercontrol 8 range the console moves the selected fader into the first bank of 8.
Can anyone help with with getting both devices to function without that conflict?
Old 05-03-2010, 03:06 PM
snake doc snake doc is offline
Default Re: Axiom Hypercontrol vs D Command
Having the same issue with Control 24. Just posted about it in the Control 24 section. Let's hope there is an answer for this.
www.christurbiville.com
Axiom Pro/ProTools9/Hypercontrol problem clausiii MIDI 47 06-07-2011 02:25 PM
pro tools m-powered 7.4 + axiom pro 61 + hypercontrol Cbeaulne 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 02-19-2011 11:54 AM
axiom pro hypercontrol and pro tools - why no workie? tunespin MIDI 10 09-28-2010 11:31 PM
Windows 7 + Axiom Pro Hypercontrol = Not working? DeyBwah MIDI 8 04-28-2010 07:21 PM
Windows 7 + Axiom Pro Hypercontrol = Not working? DeyBwah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 02-15-2010 04:02 PM
