DAE error #7400
Windows xp/digi 002 rack/ pro tools 6.1.
I got a error message " DEA #7400 "...what its meen??? I can't run some plug'in since I got this trouble!!! I change the playback buffer but no change !!! plz help me!!! |
Re: DAE error #7400
Does it say anything else than just "DAE #7400"?
Re: DAE error #7400
I get this all the time as well. Sometimes it happens when I open a session and PTLE can't open a plug-in, the 7400 error makes them in active. I think the error says something like DAE error 7400 unable to open plugin or something like that. The only thing I can figure out, is it might be another bug with the T-Racks bundle. Strangely, when I get this error, I have to open a T-Racks EQ on a track then take it off. After I do that I can open the other "inactive" plugs. Sometimes when the session starts I can just click on the DAE inactive plug and they open up. Kind of frustrating. It seems to happen with Sampletank, and the Free Bombfactory plugs the most. It's hit or miss on my system. If you do a search for 7400 error there are some threads where people have to copy the affected session to the other drive and recopy it back and that seems to cure it as well.
FYI: I'm running PTLE 6.4cs9 with a Digi 002R, on a P4 2.8 ghz with a MSI 865G chipset mobo, 1 gig of Kingston Ram and two 80 gig Seagate 7200rpm SATA hard drives. Other than that I have no idea what causes this. |
Re: DAE error #7400
starting to happen too. But not on sessions but with the same plugins
Docta'J Download free music at http://www.nukmusic.com nEVER uNDERESTIMATE kNOWLEDGE |
Re: DAE error #7400
I used to get that error when duplicating an amplitube plugin to another track using the alt click copy shortcut.Might be some ik multimedia error.
Davec 1 results,32+68 at 1024 buffer,32+ 41 at 128 buffer both 24 bit |
Re: DAE error #7400
I found what helps my computer. i had the same problem with dea 740 when I went to use auto tune and amplitube plug in. when you go to the session Icon. with the song tittle to open the session. right click and uncheck archive, then re open the session. every song I had a problem with works perfect now. check it out...
Error 7400, Would really appreciate help ! | Wayfaerer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-23-2010 09:16 AM |
DAE Error -7400? Help! | Stixntrixx | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 14 | 08-25-2009 12:33 PM |
KEEP GETTING DAE error 7400 | dwayne00 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 15 | 03-18-2009 03:00 PM |
DAE error 7400??? | jonah day | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-29-2006 12:23 PM |
Auto Tune Error----- DAE Error -7400??? | Lance Driskell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 12-06-2005 01:51 PM |
