Old 01-08-2002, 08:46 AM
RpwBass RpwBass is offline
Default Best sample library location?
I am running a G4 DP500 with 512 mb, 30gig ide system drive, 30 gig IDE 7200 rpm second drive for audio. Would it be advisable to keep my sample library on the system drive or the second drive that is also used for audio? I'm not sure which would get better performance. Thanks!
[img]images/icons/shocked.gif[/img]
Old 01-08-2002, 02:20 PM
joy4u joy4u is offline
Default Re: Best sample library location?
I use the internal IDE drive for:
64 tracks audio total SSC library
(SSC loads samples to )
Old 01-08-2002, 03:26 PM
jeffro's Avatar
jeffro jeffro is offline
If you are choosing to store the files on a drive instead of the the CD, then either drive would work.
Performance (as in, how fast you can load a SampleCell Bank) should be similar between the drives. The deciding factor might be how much space is available, and possibly needed in the future, on each drive.
linkedin
Old 01-08-2002, 06:11 PM
Jahmontee Jahmontee is offline
I drag n drop all of my SampleCell CD's on Aladdin's "ShrinkWrap" and make a virtual cd, which then I store on my main os drive for easy access and quick loading...
Just my 2 cents
Jahmontee
Old 01-09-2002, 06:09 AM
Wow....Thanks for all the advicce!!!!
I should clarify my question....By "performance" I mean that I'm concernered that having large amounts of samples running from the same drive that handles my audio tracks in Protools may bogg the computer down. I wasn't sure if I should move the samples to the system drive because that drive needs to be free to access the operating system and Protools itself. I guess it's a drive speed issue. Thanks for the help guys....I can always count on the pro's here!!! [img]images/icons/grin.gif[/img]
Old 01-10-2002, 12:00 AM
zeeman zeeman is offline
remember, your not streaming the samples. once they load, it's done. all you are taking up is ram from the processor. i just drag all of my ssc cd's onto a 80gig firewire drive and load from there. it's real fast and i'm able to bring my library with me wherever i go.
it's pretty cool.
another 2 cents.
cmz
MAC OS 13.6.1
Mac Mini M2 16gig Ram
PT 2023.12
Lynx Aurora 16n Thunderbolt
Old 01-10-2002, 08:15 AM
Thanks Zeeman....I'm not sure how I overlooked that fact. That makes a lot of sense! I knew I could count on you guys here!! Thanks again!
HTML code is On
where is the User library default location bear0328 Pro Tools 11 4 05-01-2014 01:19 PM
Sample Storage location XD8Buser macOS 5 01-15-2011 06:54 AM
Structure Library Location jbr Virtual Instruments 2 08-27-2010 01:18 AM
structure LE library location Mr.O Virtual Instruments 3 09-06-2009 02:19 PM
NI komplete kontakt library location? crizdee Pro Tools TDM Systems (Mac) 14 08-11-2009 05:51 PM
