Old 08-11-2011, 09:53 AM
ofmice ofmice is offline
Default earphones vs speakers
When I use earphones with PT, the sound is very good, loud. But when I use external speakers, the sound is weak and crappy.
What causes this?
Other recordings played through Windows Media Player sound good and loud through the speakers.
But when I put it into PT for editing, then it sounds lousy through the speakers, but good with earphones.
I have LE8, Mini MBox, sony viao i5, windows 7.
Old 08-11-2011, 06:48 PM
Charles D. Ballard Charles D. Ballard is offline
Default Re: earphones vs speakers
Most headphones are designed to make things sound good. Though regular home stereo speakers are also designed to make things sound good, they are less forgiving than headphones.
Proper monitoring speakers are designed to truly represent the actual audio which should point out any problems.
My advice (without purchasing more equipment) is to mix for the speakers and the headphones will sound good, too.
-Charles D. Ballard, M.P.S.E.
"I bent my wookie"
Old 08-12-2011, 10:56 AM
Good advice, but there's more to it. First off, what speakers? Then, how is the room treated for acoustics(the best speakers in the world can sound like crap in a bad room). Have you checked all your wiring(if the speakers are out of phase due to bad cables, then you're screwed).
Old 08-12-2011, 11:15 AM
all other recordings sound good and loud through these speakers, including from Windows Media Player.
only when it's coming from PT does it sound weak in volume through external speakers. I bounced a disk from PT, and this CD also sounded weak in volume.
Can't figure this out. thanks for the help.
Old 08-12-2011, 11:52 AM
Very true.
So, are you saying that you are listening to Windows Media Player through your Mbox Mini (connected to an amp and speakers) and it sounds fine, but when you listen to Pro Tools through your Mbox Mini (connected to an amp and speakers) you're having a problem even when listening to the same file, but when you listen through headphones plugged into the Mbox Mini both Pro Tools and Windows Media Player sound fine?
"I bent my wookie"
Old 08-18-2011, 11:43 AM
themadarchitect themadarchitect is offline
What causes this?
Is "loudness" the issue or is it quality degradation?
Anybody knows KEF Q 300 Speakers marrap Post - Surround - Video 8 03-13-2011 12:39 PM
DEBATE: Using other speakers and crappy speakers to check mixes! DJ Hellfire Tips & Tricks 15 06-03-2010 08:46 PM
600ohm iPod type Earbuds/Earphones.. kurt Tips & Tricks 4 04-06-2007 09:29 AM
Earphones & Hearing Damage Da Gatekeepa 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 06-11-2005 06:08 AM
Big Speakers!!! Ross H 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 09-27-2004 10:45 PM
