Waves InPhase and Delay Compensation?
Hi all,
I recently picked up a copy of Waves' InPhase plugin and am finding it doing something odd that I'm guessing has something to do with PT's Delay Compensation. First question; am I right in thinking that delay compensation only affects the output of tracks, and not say a bus send from a track, or maybe the input to a plugin on a track? In other words, a track showing a delay compensation of 1920 would have its playback output shifted back 1920 samples, but the bus send and plugins would be seeing the audio before the shift? What's happening with InPhase is this: I'm attempting to use it to phase align two mono audio tracks, a DI guitar and a reamp'd signal. Naturally, the amp signal is behind the DI. In the Edit window it appears to be less than 1ms behind. Waves' tutorial videos suggest putting InPhase on the amp track and using a bus send from the DI track to feed the side chain input on Inphase. When I do this though, the amp track appears ahead of the DI in Inphase (!) If I reverse the setup and put InPhase on the DI track, the DI track then appears ahead of the amp, but by a much bigger than "natural" amount (over 20ms). I've played with turning Delay compensation on and off, which seems to have no effect. Any thoughts? Thanks! Tom PT HDX 11.3 on Mac OS 10.9.5, 8 core 2.4Ghz Intel, 24GB RAM, Waves v9. |
Re: Waves InPhase and Delay Compensation?
Why not get rid of the plugins, zoom in far enough to see the samples (or close to it), grab one of them and manually move left or right until it closely matches the other waveform? What you're trying to do is SO SIMPLE it doesn't require the extra processor power of some silly plugin... know what I'm sayin'?
Eric Seaberg • San Diego, CA A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S. |
If I am not mistaken, Sidechain ADC is an HDX only feature
I do this all the time though with my HDN setup Just be sure that you don't have plugs causing much/any latency on your Sodechain Dource track. And if you do, print that track before sending to InPhase As far as what Eric is asking. One good example of why to use InPhase over doing it manually is when phase aligning drums or anything with multiple tracks that would benefit from the same movement. Set InPhase, open as AS plug, and render as many tracks as needed. Tadda Also works well when aligning tracks that will go to someone as individual tracks / stems - so when imported they still align, without the need of the additional steps of consolidating and purging session audio files And, when you get quick with InPhase, it can be faster than doing it manually I'm sure there are many other great reasons I'm not thinking of right now. I just woke up I use InPhase a lot and love it!
Shorty: Table Syrup Records Mac Pro 5,1 3.33 GHz Hex, 32GB EFI Flashed - 5 GT/s Modded 7950, Dual Apple 23" OSX Sierra Pro Tools HD 11.2.2 Waves IOS, IOX, STG2412 Extreme Server (x2) Logic Pro X, DSP Quattro, Final Cut Pro X Waves Mercury+SSL+AbbeyRoads Trident S65 with embedded US-2400 Live: 2012 Mac Mini, Dual SSD, i7 2.4, 16GB Win 10, OSX Sierra LV1, MRSG Hardware from above (same gear) Dual Dell P2418HT Touch Screens Waves Icon X (x2), M, with Screens Custom enclosure |
You are not mistaken
Why would you ever want to align drums?! I've gotten in so many discussions with people about this. What you're changing isn't phase, but timing information relative to panning and placement. My gosh people... how many years before digital have incredible sounding drums been recorded?! If your micing is right when it goes down, and you like the way the drums sound, leave them alone (pretend like this is all caps).
What to do if the miking wasn't right tracking a multi-miked drumkit - due to time constraints, stress, inexperience, lack of overview in a complex situation or simply missing to locate the issues during recording? Can you still not use these correction tools with any benefit? Is there absolutely nothing to win using them afterwards? I'm asking politely and genuinely
I do it when I'm looking for very tight, very punchy, super crisp drums... and yes it does make a substantial difference - and sometimes the difference in time between mics does cause phasing sounding drums - so this can correct that - in fact, more often than not, I've noticed more that it's after you've done it - if you A/B the drums from beforehand, that's when you hear what was 'wrong' with the original drums.
Not looking for an argument... do what works for ya... don't do what you don't need or want to do. that's fine. all that matters is the end result. Just because this wasn't done with drums before the technology wasn't there, doesn't mean it isn't necessary or that it doesn't make it better when needed. There are many styles of music, and sometimes super tight, crisp, clear, punchy drums are what's really needed to make a track shine. I often do it even with incredible sounding recordings that were done right, and yes, it can improve them. That is in no way wrong. And then, other times, leaving them alone is perfectly fine. I work both ways, depending on what is needed. Neither is right nor wrong
hjorte - that is a good example
I get a lot of sessions like this - that I did not record - and they benefit from it substantially in the edit/mix process.
That's all I'm saying. If you NEED the tools, so glad they're there, but don't use them just to use them. I'm done... thanks for the soapbox.
Especially what I like in InPhase is phase filters that sometimes can help to remedy very annoying phase problems. I think there is no other plugin having that feature. |
Waves Problems with delay compensation | RTASW | Pro Tools HDX & HD Native Systems (Mac) | 18 | 04-28-2013 11:57 PM |
Waves inphase anyone trying it? | Raoul23 | General Discussion | 1 | 02-20-2012 12:03 PM |
Waves InPhase | danander11 | General Discussion | 5 | 01-21-2012 04:20 AM |
Delay Compensation issue... Is it Waves? | acacia | Pro Tools TDM Systems (Mac) | 7 | 03-18-2010 11:53 AM |
Waves Tune and delay compensation | Anibal | Pro Tools TDM Systems (Mac) | 7 | 09-25-2006 06:51 PM |
