Venue Live Sound Environment
I don't know where this post should really go so I guess here is fine:
I was wondering around how much the Venue Live Sound Enviroment System will be going for. Always, I'd like to know how the outputs to the speakers work on it. I understand everything but the main speaker outs, where are they? Any help would be appreciated. Thanks, Andrew |
Re: Venue Live Sound Environment
quote:
"SRO Output Card Each SRO (Stage Rack Output) output card provides eight balanced analog line-level outputs. A green signal presence LED aids in troubleshooting. A red output mute LED shows the action of the output muting relays, designed to eliminate power-on transients. SRI and SRO cards are user-installed options, allowing operators to expand a rack configuration as needed." I believe you can use any of those outputs as your main outputs |
another quote:
"FOH IOx Card The FOH IOx card features eight AES digital inputs and outputs, allowing operators to integrate outboard gear with digital connections. In addition, the FOH IOx card expands the insert and direct output capability at FOH by adding eight balanced analog inputs and outputs on TRS jacks, allowing connection to virtually any type of outboard gear. All I/O connections are fully routable in the digital patchbay, facilitating easy access to any internal digital pathway." so if you want your main outputs to be at the FOH position you should be ablo to use these outputs as your mains as well... |
Well what I was going to end up doing is taking the outputs from the Stage Rack into another Venue Live System for a monitor mixer because I need around 24 stero monitor mixes. I thought that the TRS jacks on the FOH are monitor feeds / FX send - returns.
Any help any one ?
I think I figured it out. How much does one of the Venue Live Systems go for ? Any help would be appreciated.
Thanks, Andrew |
Non venue hd2 for live sound | 68topls | VENUE Live Sound Systems | 2 | 12-10-2009 03:50 PM |
Safe to use mbox2 mini in Live Environment? | RageD | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 03-29-2009 10:45 PM |
loop production environment instead of "LIVE" MAC? | KingFish | General Discussion | 0 | 03-03-2005 03:30 PM |
Digidesign VENUE Live Sound Environment | sinnic | Pro Tools TDM Systems (Mac) | 1 | 09-16-2004 03:07 PM |
going from studio to live environment | jlee462 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-04-2003 11:12 AM |
