Old 03-20-2020, 06:51 AM
priorytools priorytools is offline
Default Pro Tools Follow/Bank To Layout ?
Is there a way to have pro tools edit & mix windows follow / reflect a layout ?
IE- if I have a layout (1) that is a 24 tr master from an analogue transfer & another layout (2) that is the 24 tr slave.
When I hit layout 1 I'd like pro tools to jump to those channels .
And the same when I select layout 2 . .
Cheers .
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
Old 03-20-2020, 07:00 AM
creativecontrol's Avatar
Default Re: Pro Tools Follow/Bank To Layout ?
Greetings,
Unfortunately there is no simple way to do this since layouts can contain discontiguous tracks spanning up to 8 different workstations. Even on a single workstation scenario, if the justification oriented to the first track it’s quite possible that the other tracks in the layout are not right adjacent to it.
My recommendation would be to use Shift + Control then touch the Select on the specific track (possibly the first) in the layout you want to top/left justify in the Pro Tools Edit/Mix window.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 03-20-2020, 08:26 AM
Hi Jeff. .
I hope all's ok with you & yours in these strange times. .
Thanks, yes, I figured that, but just thought I'd check with the Guru. .
shift+ctrl select is my friend . .
Old 03-20-2020, 08:44 AM
While you're here Jeff, the automation Trim softkey here is slowly flashing .
All automation is off.
Any idea why it's flashing ?
regards
JJM
Old 03-20-2020, 08:49 AM
Usually that would indicate that you have uncoalesced Trim data. If Pro Tools (Setup>Preferences>Mixing) was set to Coalesce Trim Automation = Manually, there are likely trim moves that haven’t been applied / coalesced. You could also be in “On Exiting Trim Mode” and simply never have left Trim mode so the coalesce didn’t occur. If you pop into On Exiting Trim mode and Option all Channels in and out of Trim it should clear the indicators.
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Old 03-20-2020, 09:06 AM
I have coalesce set to after every pass. .
And there is no automation in this session. .
I have tried as you suggested, still flashing.
Delete special, all automation, still flashing. .
Quit PT, re opened, no flashing. .
Cheers
Jeff.
Old 03-20-2020, 12:38 PM
Thanks for the update. I will inquire with engineering and see what we know.
best,
Jeff
Jeff Komar
Solutions
S6 FAQ
MTRX FAQ
Pro Tools not following my layout tracks hugoleitao Avid S1, S3, Dock and Control App 10 01-04-2019 03:09 AM
spilled layout changes display layout kava Avid S4/S6 5 09-05-2018 12:42 AM
Avid Artist Series Bank Nudges Instead of Bank Impervious Artist Series 14 10-27-2017 09:07 AM
Mc mix-protools 9- bank select follow? priorytools Artist Series 1 11-08-2011 10:57 AM
Bank D on SC48? Future Custom Bank perhaps? digidesigner VENUE Live Sound Systems 1 01-11-2010 07:20 AM
