Old 10-04-2017, 03:48 PM
Nathan W. Nathan W. is offline
Default AAF from Premiere works! (sorta)
For the first time in my career we actually got an AAF to work with Protools with one caveat: all the audio clip names are totally messed up and I have no idea why. It looks like it's taking the video clip names and not the original audio names. Anyone know anything about this? Trying to get original clip names in the AAF files.
Nathan
Old 10-04-2017, 08:15 PM
minister's Avatar
minister minister is offline
Default Re: AAF from Premiere works! (sorta)
Are you SURE that they are giving you Production Audio?
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 10-05-2017, 05:54 AM
tom_lowe tom_lowe is offline
Nathan
They probably created sync'd clips, they take the name from the video clip.
Old 10-05-2017, 07:40 AM
Yes--for the show I'm working on there wasn't a separate field recorder used like a 664 and I don't use field recorder workflow; they break out all the audio for me for mix in their timeline(s.) Audio is embedded directly into quicktime files during recording. I think they use a Pix260i. Even the voiceover I record for them and they insert themselves comes back to me named some graphic file which makes no sense.
Old 10-06-2017, 03:50 AM
StefB's Avatar
StefB StefB is offline
Pix will not keep audio file track names in "Video & Audio" mode - only when used in "Audio Only" mode (not recording video). When they sync your clips it will retain whatever the file name was for the video/graphic.
Mac 16 Core 7,1 -Os 10.15.7 - 96 gb Ram - Pro Tools 2022.6 Ultimate in 5 suites - MTRX Studio -S6 26-5-D - Sync HD - Video Satelite (Symphony 2022.5, AJA Kona 3g) Pro Protools 2022.6 Vanilla in 21 x Recording and Edit suites. Mac 6,1 Mac Mini, Mac Mini M1, Mac Studio Pro, Mac Studio Max
Mediacomposer 2021.12 on AJA Kona 3g / XT I/O x 3 suites. Multiple Avid S1, S3 & Docks
Old 10-06-2017, 07:56 AM
Yes--however, when I feed them an audiofile (voiceover) it comes back to me as a totally different name, some sort of graphic file name. Makes no sense, unless they're syncing the audio to a video clip and then the aaf gets the name from the video clip.
In any case, the OMF file actually gives me the name of the video clip from the Pix260i which I want, but the AAF gives me something else--graphic file names, etc. which make no sense to me.
Old 10-06-2017, 07:58 AM
So how do you fix this in Premiere? Is there a way for editors to "unsync" clips so you get the correct naming scheme, one that makes sense? We do use the Pix260i but even when I feed them a voiceover file and they give it back to me in an AAF it gets its name from a graphic file, not the file name I give it. Makes all the file names totally useless to me.
Old 10-06-2017, 02:35 PM
marsian marsian is offline
Today I got an embedded AAF out of Premiere. Audio consists of stems that have been recutted with picture. All of them remained their original filenames after importing session data in Pro Tools 12.8.1.
Cheers
Maik
PT HDN 2024.3, OMNI, SYNC HD, Dock, 2xS1, PT Control, MacPro 5,1 12core 48GB, OSX 12.7.4, BM Decklink Extreme 3D
mars13.de
Old 10-06-2017, 02:54 PM
noiseboyuk noiseboyuk is offline
Getting an AAF from Premiere with real clip names is definitely doable, but I don't know what the settings were (helpful I know). Passing source timecode was definitely not doable when we tried earlier this year. EDLs and EdiLoad made it relatively painless in the end.
Guy Rowland
www.guyrowland.co.uk
www.sound-on-screen.com - Original audio clips of movies, TV shows and games, licensed as regular production music.
PT 2024 Ultimate; W11 Pro; Ryzen 9 7900; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i
Macbook Air M2; 24gb RAM
Old 10-14-2017, 11:01 AM
I was never able to get it to work with the editor--exporting an OMF to Audition and OMF out from Audition to ProTools seems to be the best method.
If anyone has any more info on this or how to get an AAF out of Premiere while keeping original file names, please provide detailed steps! Would be greatly appreciated!
HTML code is On
Need some mic advice *sorta off-topic* xbook Tips & Tricks 2 12-13-2006 06:54 PM
Startup problem (sorta) senectavit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-17-2006 04:01 PM
Did they sorta break the trimmer? remainanon Pro Tools TDM Systems (Mac) 0 08-31-2005 10:25 PM
sorta OT: Can't install OSX on Volume HELP!!!!!!! KingFish 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-09-2005 12:22 AM
Sorta OT: Problems with Roland jx-305 timmygrimm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-17-2002 08:38 AM
