Old 08-17-2005, 03:43 PM
ryhiller ryhiller is offline
Default Original disk allocation cannot be used????
Please help!
I am in the middle of a session, and have not done anything out of the ordinary, but today as I attempted to open a session, an error message read... "The original disk allocation for this session cannot be used. One or more drives could not be found, or are invalid for this session. As a result, disk allocation has been modified. Would you like to verify the new disk allocation?"
If I choose no to the option of verifying the new disk allocation, another message reads, "Audio files are on volumes unsuitable for playback. Would you like to copy them to a suitable volume?"
I have been running Pro-Tools up till now, successfully, using a Lacie external firewire hard drive, and have been able to pull up the sessions with no problems. There is also plenty of space on the drive, so I am completely at a loss as of what to do.
Thank you in advance for your replies- Ryan
Old 08-17-2005, 04:49 PM
Charles D. Ballard Charles D. Ballard is offline
Default Re: Original disk allocation cannot be used????
Check and make sure the disk you're using did not get changed somehow to a "Transfer" volume. To do that, go to Window --> Show Workspace. Check the "A" column on the drive your session files are on and make sure there is an "R" (for Record) or "P" (for Playback) and not a "T" (for Transfer). To change it, click the letter and select the mode.
If this is not the case, we'll try something else...
-Charles D. Ballard, M.P.S.E.
"I bent my wookie"
Old 08-18-2005, 02:54 PM
You are the man!!!!!!! That fixed it right up!!!
I wonder how the workspace was changed in the first place though, because I never even opened it?
Anyway, thank you so much, your advice saved my ass!
Ryan
Old 08-18-2005, 03:09 PM
Glad to help.
"I bent my wookie"
The original disk allocation for this session cann hws 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-20-2006 12:18 PM
Disk Allocation questions and disk error messages 3rdstory 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 01-30-2006 09:10 PM
original disk allocation??? what this mean??? pierreram 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-14-2005 09:44 AM
Original Disk Allocation Not Found!!?? Wheate 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-24-2004 04:04 PM
Original disk allocation can't be used tigergod 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-13-2004 07:19 AM
