001 interface mutes after region delete
This is driving me crazy...Sometimes when I select across a couple regions and hit delete (in "Shuffle" mode), I get a loud "pop" in the monitors. After that, I can't get any audio out of the 001 until I quit and relaunch Pro Tools. I can see the meters working in the Mix and Edit windows before I quit PT.
Any ideas? Mac G4 667MHz OS 9.1 PT 5.1.1 LE Glyph Project X Firewire drive Mackie HR824 speakers |
Re: 001 interface mutes after region delete
There have been a few posts about this...search for "pops...then audio goes bye-bye" or something like that. It seems to happen most when editing and there has never been a solution to this other than Digi's standard answer of "We couldn't duplicate this problem on any of our machines". The only things there is to do is save the session, close it, and re-open it (at which time you will hear another pop) or you can change your DAE playback engine (Which does the same thing).
Either way the only way around it is to save/close/reopen. You shouldn't have to reboot PT's every time just re-open the session. Hope this helps some. [img]images/icons/grin.gif[/img]
I.B.S. Studios |
Hey Nine Spine,
Thanks for the info! |
PT8 can't delete multiple region Playlist! | Sutee Sangsareechon | Pro Tools TDM Systems (Mac) | 1 | 12-20-2008 12:29 PM |
Delete key deletes wrong region | zman76 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-30-2004 08:42 AM |
Weird: Making inactive mutes my interface outputs | Impala | Pro Tools TDM Systems (Mac) | 0 | 12-14-2003 03:56 PM |
trying to delete part of region deletes all!! | sphereman | Pro Tools TDM Systems (Mac) | 0 | 12-04-2003 07:47 AM |
In case delete region, my PT 5.1.3 delete all regions on track. What is it? | kwarkot | Post - Surround - Video | 0 | 12-04-2002 12:38 AM |
