PT 10.1.2 D-Command meter issue
After installing 10.1.2 on an HP xw8600 running Win 7 Pro 64 bit, the center meters on the D-Command no longer follow the main input. This has always worked for this system. I have reset the X-mon, the d-command, trashed prefs. The drop-down menu in I/O setups was always set to out 1-8 so the meters would follow the output. The odd thing is, the alt surr and stereo inputs DO follow on the center meters. If I set the controller meter path to the exact same hardware output as the Main input, the meters are active. Set it back to out 1-8, nothing for the Main input. Is this a known issue with 10.1.2?
Re: PT 10.1.2 D-Command meter issue
I have the same issue. I am running an HDX PT 10.1.1 on a mac. The meters were working fine up until a couple of days ago. I have changed the Controller meter path to stereo only and it worked. switched it back to out 1-8 and no meters.
Please let me know if you find out anything and ill do the same. |
D-Command CUE issue | rdavis21 | ICON & C|24 | 1 | 05-05-2010 09:27 PM |
Command 8 Meter adjustment?? | djryno | ProControl, Control|24, Command|8 | 1 | 04-02-2010 08:59 AM |
Can D-Command show Gain Reduction on the Meter Bridge? | macaholic | ICON & C|24 | 3 | 02-13-2008 12:28 PM |
How do I reset the meter on Command|8? | mrllnfn | ProControl, Control|24, Command|8 | 3 | 03-17-2007 05:17 PM |
