Old 02-02-2012, 04:04 AM
JazzyJ JazzyJ is offline
Default Change Track size of selected tracks?
How can I change the size of selected tracks in the Edit window?
• Right Click or cmd click gives options to change 1 track
• alt click changes ALL tracks
If I've highlighted 6 tracks in the left - so the names are 'highlighted white' - how do I just enlarge or shrink those tracks with affecting the others? Oh yeah, also - and without creating a group. I just want to be able to select tracks and for the selected tracks to all do the same thing.
Thanks
Hack Pro (4.2Ghz i7 Quad/16GB)
PT11 / OSX 10.8.5
TC Electronic Konnekt 24D
Old 02-02-2012, 04:44 AM
elicious elicious is offline
Default Re: Change Track size of selected tracks?
shift-alt
e
ihatetyping
Old 02-02-2012, 04:59 AM
PD-John PD-John is offline
You could also try using Zoom Toggle (see Preferences > Editing to set it up). Then for whatever tracks you have selected, just press "E" and they will become the size you've specified (with Edit Focus mode on). Saves you having to use the mouse, if that helps
Old 02-02-2012, 05:08 AM
shift-alt
Nice one!
I swear I'd tried every combination of alt, shift, cmd........
I'm going mad.
PT11 / OSX 10.8.5
Old 07-15-2020, 09:44 AM
joradsilver joradsilver is offline
FYI on mac for PT 12 its cntrl+e to change selected tracks to fit edit window
Very slow track size change! fretfingers Pro Tools 11 11 03-31-2014 06:24 PM
Key Command Edit Window Change Track Height All Selected? DFT Pro Tools 10 3 03-08-2013 02:20 AM
[solved] Change the waveform size of audio on a single track, not whole session rockguitarist1255 Pro Tools 10 4 12-12-2012 08:39 PM
Can't change MIDI editor track size soundboy35 Pro Tools TDM Systems (Mac) 1 12-24-2008 04:22 PM
Change Output channel for selected tracks *DELETED* Micah777 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-15-2004 01:43 PM
