Old 01-03-2007, 05:41 AM
ron player ron player is offline
Default what can you squeeze out of your macpro?
Hey guys,
I'm on the verge or purchasing a MacPro and would like to know what performance your getting out of your machine. ie 24 audio tracks, 2 soft synths, reverbs, eq etc.
Thanks in advance for any replies...
Old 01-03-2007, 06:27 PM
sunburst79 sunburst79 is offline
Default Re: what can you squeeze out of your macpro?
I believe Nikki-K was getting 190 Dverbs. If thats any help.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 01-03-2007, 09:06 PM
lwilliam lwilliam is offline
I haven't seen or done any PTLE tests with the MacPro, but SOS (current issue) did a test with Logic Pro.
A few examples of how many instances of Space Designer they were able to run:
Mac Mini 1.42Ghz G4 - 4
iMac 1.8Ghz (G5) - 17
iMac 1.83Ghz Core Duo - 30
PowerMac 2.7Ghz DP G5 - 34
Mac Pro 3Ghz Dual Xeon - 52
Space Designer is like Altiverb, but not as nice-sounding. It's more CPU efficient though. A rough estimate might be 1/2 the number of Space Designers for the approximate # of Altiverbs.
You can see the Core Duo iMac is almost as fast as the DP G5.
I used to just get 32 mono audio tracks out of my old G4/400 and PTLE 6.9, so 32 should be a walk in the park for one of the new machines.
Hope that helps.
Larry
PT 2021; MacBookPro M1; 16GB; Spectrasonics; Native Instruments, Toontrack, Waves...too many plugins.
Old 01-04-2007, 01:30 AM
Cheers guys.
That's a help.
I've heard good things said about the altiverb. I must check it out.
how many tracks can i squeeze from PT LE manis Post - Surround - Video 6 09-12-2007 06:38 PM
What can you squeeze out of your macbook pro? ron player 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 01-09-2007 08:28 AM
What can you squeeze out of your macbook pro? ron player 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-03-2007 05:38 AM
what means squeeze in the bounce window??? floplight Tips & Tricks 1 10-15-2003 11:39 AM
*** Time Stretch/Squeeze & Pitch Change *** Dan Clark Tips & Tricks 5 10-09-2002 04:17 PM
