Setting beginning and end points
How do you set where the end point of a song is? I know I've read if before but I can't find it. But when I bounce a song it always takes longer than the song really is. So I'm sure there's a way to set an end point for a session.
Digi 002R Factory Bundle P4 2.4 Ghz 1MB Cache 1GB PC3200 Dual-Channel DDR RAM 40GB HDD for OS 250GB HDD for Audio (2) 17" Monitors |
Re: Setting beginning and end points
I always highlight the portion I want to bounce. So I usually select/highlight right before it starts and right after the fade out. Additionally, you can use other software (CD Architect) to align, crop, fade song to your taste.
PT Ultimate 2020.3.0 1 HDX Card Lynx Aurora 16 (2) Windows 10 Pro 1909 ASUS X-99 II Intel i7 32GB RAM Gigabyte GeForce GTX 1050 Ti 4GB www.doylemusic.com |
Yeah I know. I just thought there's a way to mark the ending somewhere. There has to be otherwise how would PTLE know how long the song was when it came time to bounce.
PT LE would probably look for the latest event on your playlist...
>don't quote me on that, though..<
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
Interestin. I'll have to take a look at that. I guess I could highlight what I want to bounce. Just thought there was a more definitive way to do it.
How much more "definitive" could it be ?? cheers,
Hey Corey ,
Sure...I'll take that. BUT..I just drag in the time line, and that's it ...so, what's so hard about that ? Sorry if I'm missing your point... cheers,
It's just that I bounce songs a lot so I can listen to them in my car as I work on them. So if I have a lot of tracks, including midi, aux, etc., then it's kind of a pain to highlight each time I wanna bounce. It would be cool and easy to define a specific ending so when it came time to bounce it doesn't take 3 minutes longer than the song actually is to bounce the file. That's all. lol
If you know the end time of you song, just type in the value in the "End" parameter on either the time display in the edit window or in the transport window. You can also set the "Start" time in the same way. This is fast if you know the length of the song, and doesnt involve click and drag.
Be sure to press the enter key after you enter the values to make the settings stick. Hope that helps. Regards, MM |
Rec In/Out points independent from play/loop points like DP has? | spiritG | Pro Tools TDM Systems (Mac) | 0 | 10-01-2009 04:40 PM |
setting start and end points for tracks? | GMP | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 06-15-2009 10:47 AM |
Setting Loop Points Within a Sample | weezerboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-09-2009 05:08 PM |
Setting In and Out Points | John Fishback | Pro Tools TDM Systems (Mac) | 7 | 12-17-2006 09:01 AM |
help with setting loop points | Equality 7-2521 | Tips & Tricks | 2 | 07-17-2005 11:40 PM |
