Old 02-28-2019, 11:43 AM
robreed2 robreed2 is offline
Default Does anybody have 100% connection with Artist MIX?
Just a general question...does anybody have a 100% CONTINUOUS connection with Artist Mix and their set up....... Or is it just expected to SOMETIMES disconnect, and accepted as the way it is. I can guarantee that at least once a session it will disconnect and nothing brings it back with out a re start...... Not sure who is to blame, AVID, Apple ?? Just would be great and reassuring ( though I would be jealous ) if it does work 100% for some people...I'd like to know how ... Thanks
Old 02-28-2019, 12:21 PM
Southsidemusic's Avatar
Default Re: Does anybody have 100% connection with Artist MIX?
The last time we used our 4 Artist Units (2 x Mix 1 Control and 1 Transport) all black Avid branded we had them connected to one of our Trashcans with Sierra and PT 12.8.3 HD and all the units connected to one ethernet hub at 5GHz which is crucial as 2.4GHz or less will have major problems with stable connection.
The internet hub was like 30 bucks and it was a 5GHz and had 4 inputs and important - It was a POWERED HUB which was used for our 4 units.
We had tried a few before this one with only powered via the computer and another was 2.4GHz and both was crap. The hub we ended up having 1000% success with just worked and worked!!!
Had it from OSX 10.8.5 and via. Mavericks, Yosemite, skipped ElCap and went to Sierra and then Mojave but we sold the 4 units to a friend who saw how stable and awesome our setup was working even though he resd that some users had issues were one or all units was dropping out but we helped him install them and made sure he used the correct ethernet cables and set up the Eucon Software correctly and now a year on and they haven’t had one issue at all with the setup we sold him.
So yes if everything’s setup correct and if you have a Powered Hub with 5GHz and a stable ethernet connection there shouldn’t be any drops or other issues.
We had the WiFi OFF on that trashcan as you dont need to be connected to the outside internet to work them, just turn off WiFi as I believe that will make less of a fuss for Eucon to run 100%.
Let me know if you need further info or advice and I am happy to help
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 02-28-2019, 12:31 PM
THANKS SO MUCH>...I will try what you said...and come back for advice, I LOVE my artist mix, just drives me mad when it disconnects...At the moment Its connect direct to the Ethernet connection on the back of my Mac PRO 2010...I have the internet coming in the other Ethernet socket on the back of the mac...does that sound right >> Thanks ROB
Old 02-28-2019, 12:36 PM
BScout BScout is offline
100%
Artist is wired ethernet. Pro Tools Mac is wired ethernet (as is Dock and iPad). All go to a HP Procurve 1820 network switch.
Pro Tools Mac wireless is never turned on.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3
Old 02-28-2019, 12:37 PM
I will make sure that is correct and report back... and as you dont use a hub you have one less piece of gear eliminated from the troubleshooting.
Will ping Eddie who developes Eucon at Avid and see what he has for us in terms or troubleshooting. We used our interns for these setups so I might say something wrong and better to have the guy who developes Eucon chime in.
Hang tight
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Old 02-28-2019, 01:03 PM
thanks guys...I use it with Logic...which I think may be the problem !!!!
BUT if it can be solved happy days !!!!!
Old 02-28-2019, 01:09 PM
Yeah. Someone else reported problems with Logic and it dropping off. Something they did with a recent update. You should probably alert/complain to Apple.
Old 02-28-2019, 01:32 PM
Apple are useless..... Gone are the days when you could speak to a LOGIC engineer and he'd sort it out... your on your own when you buy LOGIC.... I really hope its not Logic related, as that would be like hitting a brick wall.....
Old 03-01-2019, 10:57 AM
EddieJones's Avatar
EddieJones EddieJones is online now
Yes I have heard of issues with Logic. We have fixed a couple of crashes due to Logic in the next release so hopefully that makes things better but I suspect there are others inside Logic too. Let's see in a couple of weeks whether it helps and go from there.
Old 03-01-2019, 02:17 PM
Thanks for chiming in Eddie
Have a nice weekend and hopefully the next Eucon update take care of some of these problems.
Best Regards
Christopher
#thestruggleisreal
WEBHOME
Is there anything we can do about Artist losing connection? K_BCN Artist Series 5 03-08-2016 02:30 AM
Artist Series connection issues hklydian Artist Series 1 04-03-2015 12:54 PM
Artist Control v2 losing connection with PT 10 (Mac) Trazan Artist Series 5 05-22-2014 12:53 AM
Artist Mix Connection Issue antonkang Artist Series 0 05-13-2013 02:29 PM
Unreliable connection with Artist Mix mr xy Artist Series 1 11-07-2012 08:50 AM
