Old 07-01-2013, 03:59 PM
martthie_08 martthie_08 is offline
Default sorting clips in clip list
I could have sworn to have had this one figured out, but here I go again:
In the process of making some drumsamples of my own, when auto-renaming (kick_01, kick_02, ...) the regions, I would like the clip list to mirror the clip appearance in the edit window timeline, so that individual clips will be auto-renamed in the correct order. How is this possible? None of the sorting options seem to give me what I want?!
thanks for any help!
Old 06-09-2023, 05:01 AM
Ivan Bergamo Ivan Bergamo is offline
Default Re: sorting clips in clip list
Is there any kind of workaround for this? :)
Old 06-09-2023, 10:12 AM
nednednerb's Avatar
nednednerb nednednerb is offline
If you don't clear unused clips AND batch rename the remaining clips to be sequential numbering, you will rarely get auto-generated clip names just as you like.
When I rename clips intentionally, they sort by name absolutely fine.
Sent from my Pixel 6 Pro using Tapatalk
___
>> me: nednednerB //
||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music //
||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 //
||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock //
||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR
||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts //
Old 06-24-2023, 12:27 PM
Thanks. I think I have found a work-around. So, basically, you need to select all the clips and then render them with some audio-suite plugin (let's say Duplicate - set on "clip by clip"). And then, you can sort the Clip list by "creation date", and then it will be sorted in the same order like it is in the edit window, because it was rendered in that order. And then, you can use auto-rename feature.
You are welcome. :)
PT10 - Clip List always empty (no clips show) quangaroo macOS 6 04-19-2019 07:52 AM
Exporting Clips as WAVs, clips dont highlight in list gigantorbuzz Pro Tools 10 6 08-05-2013 01:07 PM
Help with clips bin sorting please Michael Wilk Windows 0 06-27-2013 01:09 PM
Importing clips in Pro Tools 10 / clip naming legasafe Post - Surround - Video 3 10-20-2012 05:44 AM
Clip gain multiple clips workflow cjwalker Pro Tools 10 0 10-12-2012 02:53 AM
