Old 06-23-2004, 11:20 AM
superpenguin79 superpenguin79 is offline
Default Direct X plugs? Digi supported?
Just was wondering, does anyone know if LE 6.1 supports direct X plugins? Or I was figuring that I need the wrapper for those correct? I know VST's are non-compatible without the wrapper, but didn't see anything on the main digi website about Direct X, so I am assuming No? Thanks
Old 06-23-2004, 11:23 AM
Bazzle Bazzle is offline
Default Re: Direct X plugs? Digi supported?
You can't use DX plugins in Protools.
Bazzle
Old 06-23-2004, 11:30 AM
Thanks Bazzle, I was actually just going to post that I searched the forums and found it. lol I saw that you had issues with DX 9.0 before? Is there a wrapper for DX to RTAS or Audiosuite like the one for VST to RTAS that you're aware of? Thanks
Old 06-23-2004, 11:35 AM
No there is no wrapper, and my issue was a runtime error of some sort not involving plugins.
Bazzle
Old 06-23-2004, 11:39 AM
ahh, foiled in my quest for plugin expansion. drats.... oh well. Thanks anyways.
Old 06-23-2004, 11:41 AM
Hey Bazzle,
seeing as you know your PT stuff, I know I shouldn't mention other apps on the PT boards, but is it possible to use other apps with the PT hardware (I know digi wouldn't support this) just as a sound card to have plug capabilities? I won't name any software, but I heard somewhere you can do this? Thanks
Old 06-23-2004, 11:43 AM
zir zir is offline
Yes you can, in some degree.
If you have the vst-rtas adapter you can download this for free: http://perso.wanadoo.fr/vb-audio/us/...ack/dxrack.htm
Some DX plugins work within PT.
Old 06-23-2004, 11:50 AM
You can use any app that supports the ASIO diver through your DIGI HW there are lots.Wavelab,Acid Vegas,Sonar etc, etc.Most 3rd party apps support ASIO.
I have never seen until now the app that ZIR posted so I will check it out.
Bazzle
Old 06-23-2004, 12:01 PM
Thanks Zir, I will give it a shot also and see if I can't figure it out.
Old 06-23-2004, 12:25 PM
spkguitar's Avatar
dxrack is sketchy. Its a wrapper within the wrapper, and its buggy at best. Some things worked, other things didn't.
I couldn't get most dxi plugs to work at all, and sometimes it would lock up the machine with regular audio plugs.
Just my personal experience with it; YMMV.
Will the new AAX plugs be supported in other daw's? bobbybland Pro Tools 10 46 12-05-2011 11:03 AM
Direct X plugs????? sw rec 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-14-2006 10:44 AM
Will my digi 001 be supported to 6.9? the originalman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-18-2005 02:03 AM
HOW TO USE PTLE WITH DIRECT X /VST PLUGS IOP Drummer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 08-26-2002 12:13 AM
HD and Direct Connect : Do Plugs Require Updating ? Count Zero Pro Tools TDM Systems (Mac) 2 06-11-2002 04:46 PM
