Exporting Pro Tools Session into Logic Pro
Long shot, but, is there a proven method for successfully exporting a Pro Tools sessions 'Temp Maps', 'Markers' and 'Time Signature Maps' into Logic Pro?.
I don't need to export any Audio, I just need to get the basic session data - as listed above - into Logic, so that a drummer can then track his drum parts in Logic Pro. [ED: I know the sessions Bit depth and sample rates should match too] I've seen tutorials on how to import/export audio across the two, but non of them go into how to do what I'm asking?. Is it even possible, given that PT and Logic's software architecture are different?. Thanks in advance |
Re: Exporting Pro Tools Session into Logic Pro
https://www.solidstatelogic.com/supp...rted?active=17
that said .. how many songs are we talking about ???
just thinking out loud ... 1) manually - copy Tempo Maps, Time Sig's and Markers 2) see if you can get ProConvert license 3) buy Logic for 199.00 and move the songs over yourself and send drummer Logic Session 4) OMF transfer ... if you want to send me your session file in PT i can try doing OMF transfer here and see what comes across .. unless you know this will not work cheers john
Create a single midi track in your PT session, then go to "Export-Midi" & choose "Type 0" & Export that file. Then import that file into Logic Pro ... this should do what you need. It's been a while since I had to do this (Logic 8), but it should still work fine... Hope it helps.
-C' ya' Rick MacPro 7,1; 16 core OSX 13.5.2 PT 2023.9; Eucon 2023.6 Dock/S1/2x iPad |
Thanks for the response man.
I'll have 12 songs. It's my new studio album. Well I feel quite reluctant to spend anymore on software, given I've already spent a small fortune on it ha ha. But I take your point re: buying Logic, it's a good suggestion. No, I haven't even tried doing this yet, so have no clue if it would even work. so again, reluctant to spend money on something that may not work. Thanks for your offer, I may actually do this!. I could send you just the PT Session Icon, with no audio or audio folders. You'd just need the Icon as that will have all the info you'll need. Perhaps we could just test it out?. Would you mind?. Thanks for the help. |
Brilliant. :) I'll test it out at my earliest convenience and let you know if it worked. Many many thanks. Pete |
let me know if you want me to test this midi track opening in Logic ... happy to hear you have a better solution !!!
Thanks EVERYONE for the help. It is appreciated. Best Pete |
...just had a chance to check the current PT 2019.10 ref... from pg 417:
Exporting a Logic Project to my Pro Tools System | museman | Pro Tools 10 | 5 | 04-06-2015 01:34 PM |
Importing a Logic session into Pro Tools? | Scorpio253 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 12-21-2008 12:26 PM |
Logic session into Pro Tools LE | em:two | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-20-2008 12:31 PM |
Exporting PT session to Logic 7.1 | malgfunk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-18-2005 09:13 PM |
If I edit files after exporting to 2nd session, how is 1st session affected? | el biciclista | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 04-02-2002 12:01 AM |
