Old 02-24-2016, 07:19 PM
codyjtapp codyjtapp is offline
Default Pro Tools 11 Startup Error w/ New iLok replacement
Alright so a while back my iLok was broken (rampaging stepfather) I went through the RMA process and received a new iLok today with the licenses transferred to the new iLok. But unfortunately now I am having a problem opening Pro Tools after activation. I get this error message (in attachment).
What am I missing? I think this happened before the first time but I don't remember. If you can give me a link or direct me as good as you can. Thanks
Old 02-24-2016, 08:00 PM
sw rec sw rec is offline
Default Re: Pro Tools 11 Startup Error w/ New iLok replacement
Hardware error is a totally separate issue. What's your interface that it isn't seeing?
Old 02-24-2016, 08:25 PM
Try holding the N key while opening Pro Tools. That should take you right to the Audio Engine window where you can try to select your interface.
Old 02-24-2016, 09:11 PM
not sure, I usually just plug in the eleven rack to it, but even without it hooked in the usb it would still boot when I had it on my macbook previously.
Old 02-24-2016, 09:14 PM
When I pressed the n key I got this error message. Even though the licenses are on it.
Old 02-25-2016, 02:58 AM
Make sure you have the latest Ilok manager, and also disable USB power management.
Old 02-25-2016, 05:30 AM
Two more things - USB on Windows machines is picky and if you plug a peripheral into a different port than what is was originally connected to you'll get errors. Also if you have USB3 ports iLoks have been known to have issues; you'll need to get a USB2 hub to go between the iLok and computer.
Jack
QAPLA!
Old 02-25-2016, 10:26 PM
Thanks guys, I found the issue this morning. It was missing the ASIO4ALL driver. I have another problem with the audio itself but I will post in a new forum.
Old 02-25-2016, 10:57 PM
You should not be using ASIO4ALL, the Eleven Rack has native ASIO drivers. did you install those?
Pro Tools 10.3.5 Startup Error txrx Windows 13 05-02-2013 09:52 AM
Pro Tools LE startup error WindyCityUSA 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-04-2011 11:33 AM
error: missing ilok authorization for pro tools 9. please insert the necessary ilok.. weakluv Windows 2 07-07-2011 05:47 PM
DAE Error on Pro Tools startup Johnjohnjohn Pro Tools M-Powered (Win) 2 06-25-2009 01:51 PM
Pro Tools LE Startup Error bowser11 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-23-2005 02:51 PM
